sualfred 677 Posted May 18, 2017 Posted May 18, 2017 (edited) I'm facing a 100% CPU load of Emby on everyday. A simple service restart solves the problem but it happens on the next day again. I've tried to figure out what's causing it, but without success. Any ideas? Attached is the log and a screeshot of htop with the process. Edit: All I can see is that Emby tries to contact my router, which has a SatIP DVB-C tuner integrated. And some fanart.tv api issues, but the API key is correct. (I've changed it after posting the log, forgot to censor it) server-63630703197.txt Edited May 18, 2017 by sualfred
Luke 42245 Posted May 18, 2017 Posted May 18, 2017 @@sualfred, please remove all plugins except for backup and see if the issue persists with the core server. thanks !
sualfred 677 Posted May 18, 2017 Author Posted May 18, 2017 @@Luke I'll give it a try, but no plugin took action or has been triggered when the 100% cpu issue happened. It's hard to reproduce. Sometimes it starts at 1pm, today I was facing it 17 minutes after server has bootet.
sualfred 677 Posted May 18, 2017 Author Posted May 18, 2017 You mean the TV Headend plugin and the Kodi fast sync monitor? I'll give it a try. To get a better understanding of the log: It should be caused by some of the errors where restart.sh is called, isn't it? Because I only see connection problems to the metadata providers and my SatIp server (which isn't really a SatIp device.)
Luke 42245 Posted May 18, 2017 Posted May 18, 2017 I think this will be easier to evaluate with a cleaner server environment, which would be starting with just the backup plugin and no others. Thanks !
sualfred 677 Posted May 26, 2017 Author Posted May 26, 2017 So... since removing plugins did not work for me, I wiped my complete Emby installation and configuration. It seems that the issue is gone.
