radeon 760 Posted May 23, 2017 Author Posted May 23, 2017 I believe he would have to install the Android Debug Bridge and attach to the process while it was running. OK dear. I don't think that is going to happen. As a tesy he's factory reset the whole thing and disabled the screensaver an it's still the same
radeon 760 Posted May 23, 2017 Author Posted May 23, 2017 Hi, What about the restarting problem need any more info? Thanks Are you running anyour proxy or ssl setup?
screwfaze 38 Posted May 23, 2017 Posted May 23, 2017 No one box is on same network as server and another over the internet with no proxy. Thanks
radeon 760 Posted May 23, 2017 Author Posted May 23, 2017 No one box is on same network as server and another over the internet with no proxy. Thanks What devices are they? And your internal network speed? Are they on wifi or wired? Oh and your external up speed on your isp pipe would be another?
screwfaze 38 Posted May 23, 2017 Posted May 23, 2017 Nexbox A95x internal gigabit network both wired upload speed 10Mbps fibre. Thanks
radeon 760 Posted May 23, 2017 Author Posted May 23, 2017 Is it only happening with transcoded media and with the same behaviour i was having or all media?
Luke 42244 Posted May 23, 2017 Posted May 23, 2017 https://emby.media/community/index.php?/topic/24350-android-open-beta-testing/
screwfaze 38 Posted May 23, 2017 Posted May 23, 2017 I have installed the beta and seems good not restarting now will report if it happens again Thanks 1
ebr 16337 Posted May 23, 2017 Posted May 23, 2017 I have installed the beta and seems good not restarting now will report if it happens again Thanks Thanks for the confirmation.
ryankeast 1 Posted May 29, 2017 Posted May 29, 2017 Hi. This is happening to me on my Amazon Fire Tv where it will randomly restart whilst I'm watching content. What is the suggested fix for this please? On Version 1.3.35a
