aballim 0 Posted May 16, 2017 Posted May 16, 2017 HI all I'm running emby server on a Windows 10 Pro (1703) machine, with an i7-770k and a GTX 950 graphic card. Since upgrading to 3.2.15.0 I've been having problems with QSV accelerated transcoding. For the client, the program seems to hang. Looking at the logs show ffmpeg returning code 1. I copied the transcoding command from the log and got the following: C:\Users\afzal\AppData\Roaming\ffmpeg-20170516-3fefaea-win64-static\bin\ffmpeg.exe -i file:"G:\25 TV Series\Red Dwarf (1988)\Season 1\Red Dwarf - S01E04 - Waiting for God [1988-03-07].mkv" -map_metadata -1 -map_chapters -1 -threads 0 -map 0:0 -map 0:1 -map -0:s -codec:v:0 h264_qsv -preset 7 -look_ahead 0 -b:v 1847240 -maxrate 1847240 -bufsize 3694480 -profile:v high -level 4.1 -force_key_frames "expr:gte(t,n_forced*3)" -vf "scale=trunc(min(max(iw\,ih*dar)\,1280)/2)*2:trunc(ow/dar/2)*2" -copyts -vsync -1 -codec:a:0 aac -strict experimental -ac 2 -ab 192000 -f segment -max_delay 5000000 -avoid_negative_ts disabled -start_at_zero -segment_time 3 -individual_header_trailer 0 -segment_format mpegts -segment_list_type m3u8 -segment_start_number 0 -segment_list "C:\Temp\transcoding-temp\transcoding-temp\fb4db92bdd848efc8ea7dbfb140ec865.m3u8" -y "C:\Temp\transcoding-temp\transcoding-temp\fb4db92bdd848efc8ea7dbfb140ec865%d.ts" ffmpeg version N-86098-g3fefaea Copyright (c) 2000-2017 the FFmpeg developers built with gcc 6.3.0 (GCC) configuration: --enable-gpl --enable-version3 --enable-cuda --enable-cuvid --enable-d3d11va --enable-dxva2 --enable-libmfx --enable-nvenc --enable-avisynth --enable-bzlib --enable-fontconfig --enable-frei0r --enable-gnutls --enable-iconv --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca --enable-libfreetype --enable-libgme --enable-libgsm --enable-libilbc --enable-libmodplug --enable-libmp3lame --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libopenh264 --enable-libopenjpeg --enable-libopus --enable-librtmp --enable-libsnappy --enable-libsoxr --enable-libspeex --enable-libtheora --enable-libtwolame --enable-libvidstab --enable-libvo-amrwbenc --enable-libvorbis --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx264 --enable-libx265 --enable-libxavs --enable-libxvid --enable-libzimg --enable-lzma --enable-zlib libavutil 55. 63.100 / 55. 63.100 libavcodec 57. 96.101 / 57. 96.101 libavformat 57. 72.101 / 57. 72.101 libavdevice 57. 7.100 / 57. 7.100 libavfilter 6. 89.101 / 6. 89.101 libswscale 4. 7.101 / 4. 7.101 libswresample 2. 8.100 / 2. 8.100 libpostproc 54. 6.100 / 54. 6.100 Input #0, matroska,webm, from 'file:G:\25 TV Series\Red Dwarf (1988)\Season 1\Red Dwarf - S01E04 - Waiting for God [1988-03-07].mkv': Metadata: encoder : libebml v1.3.3 + libmatroska v1.4.4 creation_time : 2016-04-03T20:00:05.000000Z Duration: 00:28:32.52, start: 0.000000, bitrate: 923 kb/s Chapter #0:0: start 0.000000, end 87.920000 Metadata: title : (01)00:00:00:000 Chapter #0:1: start 87.920000, end 459.560000 Metadata: title : (02)00:01:27:920 Chapter #0:2: start 459.560000, end 746.880000 Metadata: title : (03)00:07:39:560 Chapter #0:3: start 746.880000, end 1067.600000 Metadata: title : (04)00:12:26:880 Chapter #0:4: start 1067.600000, end 1378.720000 Metadata: title : (05)00:17:47:600 Chapter #0:5: start 1378.720000, end 1654.040000 Metadata: title : (06)00:22:58:720 Chapter #0:6: start 1654.040000, end 1712.521000 Metadata: title : (07)00:27:34:040 Stream #0:0: Video: hevc (Main 10), yuv420p10le(tv), 696x568, SAR 211:194 DAR 18357:13774, 25 fps, 25 tbr, 1k tbn, 25 tbc (default) Metadata: BPS : 822268 BPS-eng : 822268 DURATION : 00:28:32.480000000 DURATION-eng : 00:28:32.480000000 NUMBER_OF_FRAMES: 42812 NUMBER_OF_FRAMES-eng: 42812 NUMBER_OF_BYTES : 176014902 NUMBER_OF_BYTES-eng: 176014902 _STATISTICS_WRITING_APP: mkvmerge v8.5.2 ('Crosses') 32bit _STATISTICS_WRITING_APP-eng: mkvmerge v8.5.2 ('Crosses') 32bit _STATISTICS_WRITING_DATE_UTC: 2016-04-03 20:00:05 _STATISTICS_WRITING_DATE_UTC-eng: 2016-04-03 20:00:05 _STATISTICS_TAGS: BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES _STATISTICS_TAGS-eng: BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES Stream #0:1(eng): Audio: aac (LC), 48000 Hz, stereo, fltp (default) Metadata: BPS : 96000 BPS-eng : 96000 DURATION : 00:28:32.512000000 DURATION-eng : 00:28:32.512000000 NUMBER_OF_FRAMES: 80274 NUMBER_OF_FRAMES-eng: 80274 NUMBER_OF_BYTES : 20550183 NUMBER_OF_BYTES-eng: 20550183 _STATISTICS_WRITING_APP: mkvmerge v8.5.2 ('Crosses') 32bit _STATISTICS_WRITING_APP-eng: mkvmerge v8.5.2 ('Crosses') 32bit _STATISTICS_WRITING_DATE_UTC: 2016-04-03 20:00:05 _STATISTICS_WRITING_DATE_UTC-eng: 2016-04-03 20:00:05 _STATISTICS_TAGS: BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES _STATISTICS_TAGS-eng: BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES Stream #0:2(eng): Subtitle: dvd_subtitle, 720x576 (default) Metadata: BPS : 3085 BPS-eng : 3085 DURATION : 00:28:16.598000000 DURATION-eng : 00:28:16.598000000 NUMBER_OF_FRAMES: 451 NUMBER_OF_FRAMES-eng: 451 NUMBER_OF_BYTES : 654279 NUMBER_OF_BYTES-eng: 654279 _STATISTICS_WRITING_APP: mkvmerge v8.5.2 ('Crosses') 32bit _STATISTICS_WRITING_APP-eng: mkvmerge v8.5.2 ('Crosses') 32bit _STATISTICS_WRITING_DATE_UTC: 2016-04-03 20:00:05 _STATISTICS_WRITING_DATE_UTC-eng: 2016-04-03 20:00:05 _STATISTICS_TAGS: BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES _STATISTICS_TAGS-eng: BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES Stream mapping: Stream #0:0 -> #0:0 (hevc (native) -> h264 (h264_qsv)) Stream #0:1 -> #0:1 (aac (native) -> aac (native)) Press [q] to stop, [?] for help [h264_qsv @ 00000000026a7040] Selected ratecontrol mode is not supported by the QSV runtime. Choose a different mode. Error initializing output stream 0:0 -- Error while opening encoder for output stream #0:0 - maybe incorrect parameters such as bit_rate, rate, width or height [aac @ 000000000260fa00] Qavg: 7321.205 [aac @ 000000000260fa00] 2 frames left in the queue on closing Conversion failed! I've tried using different versions of ffmpeg but get the same error. I've also upgraded to 3.2.17.0 and the problem persists. Can anyone help?
Luke 42201 Posted May 16, 2017 Posted May 16, 2017 Hi @@aballim, welcome. As this feature is still only expiremental, I'd like to ask for your help on this. Can you try copying the command and running it on a command prompt? Try removing different parameters until the issue goes away. Then let us know which one resolved it. Thanks !
aballim 0 Posted May 16, 2017 Author Posted May 16, 2017 Hi The included code is actually the result of running in a normal (non-admin) command prompt. I'll try as you said, removing parameters. As I don't know much about ffmpeg, I'd appreciate any hints you could give on which parameters to remove first.
Luke 42201 Posted May 16, 2017 Posted May 16, 2017 Try b:v, then maxrate. Then profile, then level. Thanks.
aballim 0 Posted May 17, 2017 Author Posted May 17, 2017 Unfortunately no amount of removing parameters has worked. As far as I can see it should work. My IGP is enabled (as is the GTX 950), I'm using the IGP as the main video card with it connected to my monitor. I know this was an issue in the past, according to various posts I've read. The problem is also reported in various places, but I've not seen a solution anywhere. It's possible that it's too early for Kaby Lake cpus, although that seems a bit strange. By the way, in my reading I found that "-strict experimental" is no longer needed since December 2015. Also they recommend using -b:a instead of -ab.
dreimer 0 Posted May 18, 2017 Posted May 18, 2017 https://emby.media/community/index.php?/topic/47568-mplayer-problems-080317/ same thing here. Kaby Lake NUC and no way to use a newer FFMPEG....
aballim 0 Posted May 19, 2017 Author Posted May 19, 2017 So we should look to ffmpeg as the source of the problem :-(
dreimer 0 Posted June 12, 2017 Posted June 12, 2017 New version 3.2.20.2 beta has checkboxes for EnableHardwareDecoding/Encoding. Disabling Encoding makes it run, but the CPU still loves me for doing so by bein used up to 90% with one transcoding process... I tried build 20170605 and v3.3.1. All the same. Last one working is v3.2.4
Luke 42201 Posted June 12, 2017 Posted June 12, 2017 Thanks for the feedback. Yes you can now enable or disable both decoding and encoding separately.
dreimer 0 Posted June 12, 2017 Posted June 12, 2017 Yeah, and encoding does not work with new FFMPEG.
Luke 42201 Posted June 12, 2017 Posted June 12, 2017 Hi, I believe it works just fine. Can you please discuss an example and attach the information requested in how to report a problem? thanks !
aballim 0 Posted June 13, 2017 Author Posted June 13, 2017 Hi all. First trial with zeranoe's 3.3.1 ffmpeg-20170605-4705edb-win64-static failed. When I selected system installed version it couldn't find it, so I pointed it explicitly at \Emby-Server\ffmpeg\20170308. The file (at the start of this thread) transcoded correctly. Note, I'm on emby server 3.2.20.0.
dreimer 0 Posted June 13, 2017 Posted June 13, 2017 I only tried to explain that the problem OP put here and I put here: https://emby.media/community/index.php?/topic/47568-mplayer-problems-080317/ still exists. Lets call it a BUMP. If you still need a full log even though the problem can be seen from FFMPEG's output, I can do so later that day when I am back home.
Luke 42201 Posted June 13, 2017 Posted June 13, 2017 The 20170308 version is our default version so what problem do we have exactly?
Happy2Play 9802 Posted June 13, 2017 Posted June 13, 2017 The 20170308 version is our default version so what problem do we have exactly? Interesting, I see a empty folder. %appdata%\Emby-Server\ffmpeg\20170308 And FFmpeg path:C:\Users\username\AppData\Roaming\Emby-Server\ffmpeg\20160410\ffmpeg.exe
nagetech 70 Posted June 13, 2017 Posted June 13, 2017 Just throwing it out there, %appdata%\Emby-Server\ffmpeg\20170308 is also empty for me. Did @@Luke roll out a new default version of FFMPEG for Emby server and i missed it? I still only have the 20160410\ffmpeg.exe I've often wondered about upgrading FFMPEG to a newer version....but didn't get many answers when I posed the question in another thread. Any insight?
Happy2Play 9802 Posted June 13, 2017 Posted June 13, 2017 Just throwing it out there, %appdata%\Emby-Server\ffmpeg\20170308 is also empty for me. Did @@Luke roll out a new default version of FFMPEG for Emby server and i missed it? I still only have the 20160410\ffmpeg.exe I've often wondered about upgrading FFMPEG to a newer version....but didn't get many answers when I posed the question in another thread. Any insight? Looks like there was a try since my beta machine show the (20170308) folder was created on 20170309 but folder is empty. But you can update and try any version you like, overall functionality is another story.
nagetech 70 Posted June 13, 2017 Posted June 13, 2017 Thanks for the answer.... I've never run any betas, just the latest stables. Guessing something went wrong with the install routine? Do you know of any benefits in using the 20170308 version? and where would I get it anyway?
Happy2Play 9802 Posted June 13, 2017 Posted June 13, 2017 I encode all my media to mp4 to avoid transcoding. But I just google ffmpeg and download and installed from https://ffmpeg.zeranoe.com/builds/. I just moved the two files to a folder in the servers default location and changed the ffmpeg path to that new folder. But it really comes down to what your are doing as the previous 20160410 version did everything I needed it to do, which wasn't much. 2017-06-13 10:44:04.3857 Info MediaEncoder: Validating media encoder at C:\Users\Administrator\AppData\Roaming\Emby-Server\ffmpeg\20170605\ffmpeg.exe 2017-06-13 10:44:04.3857 Info MediaEncoder: Running C:\Users\Administrator\AppData\Roaming\Emby-Server\ffmpeg\20170605\ffmpeg.exe -decoders 2017-06-13 10:44:04.4169 Info MediaEncoder: Decoder available: mpeg2video 2017-06-13 10:44:04.4169 Info MediaEncoder: Decoder available: h264_qsv 2017-06-13 10:44:04.4169 Info MediaEncoder: Decoder available: hevc_qsv 2017-06-13 10:44:04.4169 Info MediaEncoder: Decoder available: mpeg2_qsv 2017-06-13 10:44:04.4169 Info MediaEncoder: Decoder available: vc1_qsv 2017-06-13 10:44:04.4169 Info MediaEncoder: Decoder available: h264_cuvid 2017-06-13 10:44:04.4169 Info MediaEncoder: Decoder available: hevc_cuvid 2017-06-13 10:44:04.4169 Info MediaEncoder: Decoder available: ac3 2017-06-13 10:44:04.4169 Info MediaEncoder: Decoder available: aac 2017-06-13 10:44:04.4169 Info MediaEncoder: Decoder available: mp3 2017-06-13 10:44:04.4169 Info MediaEncoder: Decoder available: h264 2017-06-13 10:44:04.4169 Info MediaEncoder: Decoder available: hevc 2017-06-13 10:44:04.4169 Info MediaEncoder: Running C:\Users\Administrator\AppData\Roaming\Emby-Server\ffmpeg\20170605\ffmpeg.exe -encoders 2017-06-13 10:44:04.4481 Info MediaEncoder: Encoder available: libx264 2017-06-13 10:44:04.4481 Info MediaEncoder: Encoder available: libx265 2017-06-13 10:44:04.4481 Info MediaEncoder: Encoder available: mpeg4 2017-06-13 10:44:04.4481 Info MediaEncoder: Encoder available: msmpeg4 2017-06-13 10:44:04.4481 Info MediaEncoder: Encoder available: libvpx 2017-06-13 10:44:04.4481 Info MediaEncoder: Encoder available: libvpx-vp9 2017-06-13 10:44:04.4481 Info MediaEncoder: Encoder available: aac 2017-06-13 10:44:04.4481 Info MediaEncoder: Encoder available: libmp3lame 2017-06-13 10:44:04.4481 Info MediaEncoder: Encoder available: libopus 2017-06-13 10:44:04.4481 Info MediaEncoder: Encoder available: libvorbis 2017-06-13 10:44:04.4481 Info MediaEncoder: Encoder available: srt 2017-06-13 10:44:04.4481 Info MediaEncoder: Encoder available: h264_nvenc 2017-06-13 10:44:04.4481 Info MediaEncoder: Encoder available: hevc_nvenc 2017-06-13 10:44:04.4481 Info MediaEncoder: Encoder available: h264_qsv 2017-06-13 10:44:04.4481 Info MediaEncoder: Encoder available: hevc_qsv 2017-06-13 10:44:04.4481 Info MediaEncoder: Encoder validation complete
nagetech 70 Posted June 13, 2017 Posted June 13, 2017 The version I Have now does seem to do everything, I'm curious to know if the newer versions provide anything in the performance/speed department.
Happy2Play 9802 Posted June 13, 2017 Posted June 13, 2017 (edited) The version I Have now does seem to do everything, I'm curious to know if the newer versions provide anything in the performance/speed department. All you can do is try and then let everyone know it there is. Everyone's needs are different so what works for you may not work for others. Edited June 13, 2017 by Happy2Play
aballim 0 Posted June 14, 2017 Author Posted June 14, 2017 As the OP let me summarize the situation as I see it. Newer versions of ffmpeg seem to have issues with Kaby Lake and QSV. The version 20170308 of ffmpeg, however, works. As stated, it is the default version. I am on server 3.2.20.0. I needed to explicitly put in the path, however, as when I select system default, for some reason it couldn't find it. The problem, then, is a problem of ffmpeg, and mot emby. Until the problem is fixed in ffmpeg, if you want kaby lake transcoding use the default 20170308 ffmpeg. If your installation doesn't have it, then you may need to re-download. All the best$
Luke 42201 Posted June 14, 2017 Posted June 14, 2017 All of the installations have it, the only reason it wouldn't is if we were unable to download it on first startup for whatever reason, like running the startup wizard without an internet connection.
dreimer 0 Posted June 14, 2017 Posted June 14, 2017 Confirmed. Now I have a NUC7 and all is fine. So... FFMPEG as you all say ^^
