Spaceboy 2573 Posted October 22, 2017 Author Posted October 22, 2017 tested this and it works. so luke, how can we persuade you to work on channel management? 1
CBers 7554 Posted October 22, 2017 Posted October 22, 2017 tested this and it works. so luke, how can we persuade you to work on channel management? Do you have channels numbered and sorted correctly?
Spaceboy 2573 Posted October 22, 2017 Author Posted October 22, 2017 Do you have channels numbered and sorted correctly?i used before and after the uk sports changes in July and everything seems to have updated fine, channnels names and numbers. Not all logos have but they are correct per the m3u, would need more investigation to know why. Everything in the m3u seems to be reflected in Emby
Spaceboy 2573 Posted October 22, 2017 Author Posted October 22, 2017 And you have BBC1 HD as channel 1 etc?1001 but yes. The logos need updating from sd, but I can’t be bothered to fix them, they are close enough
CBers 7554 Posted October 22, 2017 Posted October 22, 2017 1001 but yes. The logos need updating from sd, but I can’t be bothered to fix them, they are close enough So you're still using the M3U file as the source with the tvg-id in?
Spaceboy 2573 Posted October 22, 2017 Author Posted October 22, 2017 Well, using the same m3u as source but replacing the text contents of the file. I’m interested to know whether changing provider within the m3u would work, can’t see why not. But then if I add a second m3u but with common tvgid and channel numbers what does Emby do then? Does it group them all together?
CBers 7554 Posted October 22, 2017 Posted October 22, 2017 Ah right. I thought you were using the M3U url direct in Emby, but that is a total disaster. The channels are all over the place. Back to the Managed M3U file for the time being then.
Spaceboy 2573 Posted October 22, 2017 Author Posted October 22, 2017 Ah right. I thought you were using the M3U url direct in Emby, but that is a total disaster. The channels are all over the place. Back to the Managed M3U file for the time being then. yes it is a disaster in terms of layout but i could live with that and order by channel last used if the provider epg went any further out than 24hours 1
CBers 7554 Posted October 22, 2017 Posted October 22, 2017 yes it is a disaster in terms of layout but i could live with that and order by channel last used if the provider epg went any further out than 24hours SD not supplying more than 24 hours?
Spaceboy 2573 Posted October 22, 2017 Author Posted October 22, 2017 (edited) No not SD, iptv provider. To use SD epg would require manual matching within Emby as the tvgids are not consistent Edited October 22, 2017 by Spaceboy
