Happy2Play 9802 Posted May 6, 2018 Posted May 6, 2018 I used Star Wars Collection as a test and no matter if sort order as by Release date or by Sort Name "Episode 1" was played. So it would appear play order is Alphabetical as release date should play "Episode IV" first. Unless a library scan is need when changing this, but proper display order was shown upon display order change.
earthtorob 5 Posted May 6, 2018 Posted May 6, 2018 Wow, I didn't expect this much attention. For some reason it's working now. I probably screwed something up. Anyone having an issue like this I recommend re-scanning your library. And making sure the files are available. Quick question, when I click play on a collection, where can I go to view the playlist?
earthtorob 5 Posted May 6, 2018 Posted May 6, 2018 I used Star Wars Collection as a test and no matter if sort order as by Release date or by Sort Name "Episode 1" was played. So it would appear play order is Alphabetical as release date should play "Episode IV" first. Some would say that Ep 1 is the first movie. If you want to follow the chronology of the story.
FrostByte 5436 Posted May 6, 2018 Posted May 6, 2018 I just ran a scan, still get the same result. Emby is running on my NAS so files are all available. 1
Happy2Play 9802 Posted May 6, 2018 Posted May 6, 2018 Some would say that Ep 1 is the first movie. If you want to follow the chronology of the story. Yes when you look at the entire story line.
dseg30 5 Posted December 8, 2019 Posted December 8, 2019 Do I not have the display because I don't have premiere? You're definitely not dreaming, My movies are all setup 'boxset-less' and Emby found which belonged in collections by itself, I never had to add a movie to a collection manually. I don't know why yours is not doing it by default, but hang in there, some one should jump in with an explanation and a solution for you. It's funny, I did not even checked the collections options, and Emby still create them automatically for me.
Luke 42202 Posted December 8, 2019 Posted December 8, 2019 Do I not have the display because I don't have premiere? HI, that's from an old version and things have changed. What are you trying to do?
dseg30 5 Posted December 8, 2019 Posted December 8, 2019 HI, that's from an old version and things have changed. What are you trying to do? Nevermind- I'm trying the auto box sets collection app. Sorry for posting.
Luke 42202 Posted July 6, 2021 Posted July 6, 2021 52 minutes ago, Edrock200 said: Does 4.6.4 add any collection ability via api? That has always been there.
