toch 1 Posted May 14, 2017 Posted May 14, 2017 (edited) Why cant I play recorded films from DVBViewer in Emby ? I can see TV but no recorded films Edited May 14, 2017 by toch
Luke 42201 Posted May 14, 2017 Posted May 14, 2017 It's possible the plugin hasn't implemented recordings yet. I would suggest adding your recordings folder as a regular Emby library.
pünktchen 1410 Posted May 14, 2017 Posted May 14, 2017 Why cant I play recorded films from DVBViewer in Emby ? I can see TV but no recorded filmsThe plugin has recordings implemented. Don't they show up or don't they play?
pünktchen 1410 Posted May 25, 2017 Posted May 25, 2017 They show up, but dont playCan you please provide the Emby server log where you've tried to play something?
toch 1 Posted May 27, 2017 Author Posted May 27, 2017 stupid question - where to find emby server log ?
ebr 16309 Posted May 27, 2017 Posted May 27, 2017 stupid question - where to find emby server log ? How to Report a Problem
toch 1 Posted May 28, 2017 Author Posted May 28, 2017 I am not sure this is correct file, but if not can you explain what you need. Can it be that emby wil not read a *.ts file? -- ( made by dvbviewer ) server-63631526396.txt server-63631526400.txt server-63631567620.txt
Luke 42201 Posted May 28, 2017 Posted May 28, 2017 It looks like there is some kind of error coming from the plugin: 2017-05-28 11:55:35.2802 Info HttpClient: HttpClientManager GET: http://192.168.0.107:8089/api/getconfigfile.html?file=config%5Cservice.xml 2017-05-28 11:55:35.4208 Error HttpServer: Error processing request *** Error Report *** Version: 3.2.17.0 Command line: C:\Users\toch\AppData\Roaming\Emby-Server\System\MediaBrowser.ServerApplication.exe Operating system: Microsoft Windows NT 6.2.9200.0 64-Bit OS: True 64-Bit Process: True Processor count: 2 Program data path: C:\Users\toch\AppData\Roaming\Emby-Server Application directory: C:\Users\toch\AppData\Roaming\Emby-Server\System System.NullReferenceException: Objektreferanse er ikke satt til en objektforekomst. ved MediaBrowser.Plugins.DVBViewer.Services.Entities.Settings.GetEntry(List`1 section, String key) ved MediaBrowser.Plugins.DVBViewer.Services.Proxies.StreamingServiceProxy.GetRecStreamingURL(CancellationToken cancellationToken, String recordingId) ved MediaBrowser.Plugins.DVBViewer.Services.Proxies.StreamingServiceProxy.GetStream(CancellationToken cancellationToken, String itemId, TimeSpan startPosition) ved MediaBrowser.Plugins.DVBViewer.DVBViewerTvService.GetRecordingStream(String recordingId, String streamId, CancellationToken cancellationToken)
pünktchen 1410 Posted May 28, 2017 Posted May 28, 2017 @@toch please paste this "http://192.168.0.107:8089/api/getconfigfile.html?file=config%5Cservice.xml" in your browser and post the answer here.
pünktchen 1410 Posted May 29, 2017 Posted May 29, 2017 Yes, the important entry is missing in your configuration file. When you look at the RecordingService config tool under Web/UPNP, there must be set a Media Stream Server Port! (defaults to 8090)
toch 1 Posted May 30, 2017 Author Posted May 30, 2017 pünktchen you are fantastic - now it is playing Perfect Thanks
toch 1 Posted May 30, 2017 Author Posted May 30, 2017 GENARALLY ( on my other pc this " reply to this topic " is not coming up - why )
