denz 501 Posted May 14, 2017 Posted May 14, 2017 (edited) Little issue with episodes not scheduled to record. What happened with this series is the episode "Immunity Challenge" had the same number as the one before it it had S9, E12 so emby didn't schedule to record it I assumed that was the reason. Then I went to icetv forum and notified them of this and they changed it as you can see it has now S9,E13 but it still didn't schedule to record then I cancelled the series and scheduled again and now it has scheduled to record. I had to do this a number of times so recording engine needs a bit of work. This is after cancelling series and then setting up series recording Edited May 14, 2017 by denz
Luke 42243 Posted May 14, 2017 Posted May 14, 2017 is there a before screenshot of from before the data was changed?
denz 501 Posted May 15, 2017 Author Posted May 15, 2017 (edited) Recycle bin came in handy here. There Tuesday 16 May episode at 1pm the pressure test that is a repeat of the night before that is why that one wasn't scheduled to control which is the correct behaviour. I had this situation before on different series where I cancel the series and then set up series recording again and all are correctly scheduled to record but it is something that shouldn't be done. Edited May 15, 2017 by denz
Luke 42243 Posted May 15, 2017 Posted May 15, 2017 Did you run a guide refresh? It seems like this should work. Does the xmltv contain dd_progid values?
denz 501 Posted May 15, 2017 Author Posted May 15, 2017 The guide is set to refresh automatically every 4 hours I have tried manually to refresh but it made no change and neither did this work for other series that I had the exact same issue. Unfortunately I didn't save the xmltv file when the issue has arisen. This is from current xmltv file <title lang="en">MasterChef Australia</title> <sub-title lang="en">2017 - Pressure Test: Andy Bowdy's Rita Cake</sub-title> <desc lang="en">The Pressure is on for the three who bombed in the Invention Test. Will their Andy Bowdy's Rita Cake bring them back from the brink of elimination?</desc> <date>2009</date> <category lang="en">Real Life</category> <category lang="en">Cooking</category> <language lang="en">English</language> <icon src="http://images.icetv.com.au/0f7f-3393-588b-df8e.jpg"width="680" height="1000" /> <country lang="en">Australia</country> <episode-num system="SxxExx">S09E12</episode-num> <episode-num system="xmltv_ns">8.11..</episode-num> <episode-num system="original-air-date">2017-05-15</episode-num> <episode-num system="thetvdb.com">series/92091</episode-num> <episode-num system="imdb.com">series/tt1433870</episode-num> <programme airingID="132060308" mediaID="21881-250814" start="20170516113000 +0000" stop="20170516123000 +0000" channel="2624"> <title lang="en">MasterChef Australia</title> <sub-title lang="en">2017 - Immunity Challenge 16/05/2017</sub-title> <desc lang="en">The best three from the Invention Test, are in the tussle for Immunity. But will it be a battle of equals?</desc> <date>2009</date> <category lang="en">Real Life</category> <category lang="en">Cooking</category> <language lang="en">English</language> <icon src="http://images.icetv.com.au/0f7f-3393-588b-df8e.jpg"width="680" height="1000" /> <country lang="en">Australia</country> <episode-num system="SxxExx">S09E13</episode-num> <episode-num system="xmltv_ns">8.12..</episode-num> <episode-num system="original-air-date">2017-05-16</episode-num> <episode-num system="thetvdb.com">series/92091</episode-num> <episode-num system="imdb.com">series/tt1433870</episode-num>
