justinglock40 0 Posted May 13, 2017 Posted May 13, 2017 (edited) Can't get 4K UHD to playback on Xbox One S. Sound plays in the background but the screen is green the entire time. It keeps transcoding. Any ideas why? Log.txt Edited May 13, 2017 by justinglock40
Luke 42206 Posted May 14, 2017 Posted May 14, 2017 Hi there, we respond to every user issue. We thank you for your patience while waiting for a response to this. Thanks !
Luke 42206 Posted May 14, 2017 Posted May 14, 2017 hi @@justinglock40, yes i can confirm that hevc is transcoding. we'll review this for an update later this week. thanks.
1ntroduc3 4 Posted May 16, 2017 Posted May 16, 2017 (edited) I have this issue also. Bookmarking this one. Tried dlna, media-player app from xbox one Chromecast function in smartphone app and xbox one app, but no 4k Edited May 16, 2017 by martheijnen
Luke 42206 Posted May 20, 2017 Posted May 20, 2017 @@justinglock40 would you mind testing again and providing an Emby server log? The first log you posted was an ffmpeg log, which was helpful. I would like to see something in the regular server log. Thanks !
justinglock40 0 Posted May 20, 2017 Author Posted May 20, 2017 (edited) Here you go: EDIT: Actually attached logs. FFmpeg Log.txt Server Log.txt Edited May 20, 2017 by justinglock40
justinglock40 0 Posted May 23, 2017 Author Posted May 23, 2017 Were you able to determine anything with those logs?
snake98 10 Posted May 30, 2017 Posted May 30, 2017 Yes we are looking into it, thanks. I'm having the same problem but with firefox and Edge. I"ve attached my logs also.
Luke 42206 Posted May 30, 2017 Posted May 30, 2017 @@snake98 you're not having any problem because browsers do not support hevc, therefore transcoding is needed.
snake98 10 Posted May 30, 2017 Posted May 30, 2017 (edited) Should I open a new Thread. I can't play hevc through firefox or edge. My understanding is that it emby should trans-code it if the browser doesn't support it. I can play h.264 just fine. Edited May 30, 2017 by snake98
Luke 42206 Posted July 22, 2017 Posted July 22, 2017 Apologies for the delay. We are waiting on a Microsoft defect to be resolved before we can enable this. Thanks.
weeks 17 Posted January 11, 2018 Posted January 11, 2018 Apologies for the delay. We are waiting on a Microsoft defect to be resolved before we can enable this. Thanks. It's Jan 2018, and I'm guessing Microsoft never resolved this "defect"? I'm on a 4k Xbox One X and can't get 4K.
Luke 42206 Posted January 11, 2018 Posted January 11, 2018 No, you should be able to play 4k now on Xbox One X. Can we see an example? thanks !
Dazog 5 Posted January 26, 2018 Posted January 26, 2018 Still Green screen IF audio is: Format : TrueHD Format profile : TrueHD+Atmos / TrueHD Codec ID : A_TRUEHD OR Format/Info : Digital Theater Systems Format profile : MA / Core Codec ID : A_DTS Also 4k HDR doesn't work.
Luke 42206 Posted January 26, 2018 Posted January 26, 2018 @@Dazog can you please describe what "doesn't work" means? thanks !
Dazog 5 Posted January 26, 2018 Posted January 26, 2018 @@Dazog can you please describe what "doesn't work" means? thanks ! The video is playing at 4k in SDR eventhough the video has HDR metadata. It's ignoring this: Color range : Limited Color primaries : BT.2020 Transfer characteristics : PQ Matrix coefficients : BT.2020 non-constant
Luke 42206 Posted January 26, 2018 Posted January 26, 2018 The video is playing at 4k in SDR eventhough the video has HDR metadata. It's ignoring this: Color range : Limited Color primaries : BT.2020 Transfer characteristics : PQ Matrix coefficients : BT.2020 non-constant Can we see the emby server log? you can learn how to locate that here: https://emby.media/community/index.php?/topic/739-how-to-report-a-problem/ Thanks.
PaulW08 2 Posted February 20, 2018 Posted February 20, 2018 I am also having this same issue when trying to play anything with audio 'TRUEHD 7.1' basically any content with Atmos. On the Xbox One X I have the green screen mentioned. On my Chromecast Ultra it plays fine video wise, but I can't get Dolby Atmos to work.
Luke 42206 Posted February 20, 2018 Posted February 20, 2018 I am also having this same issue when trying to play anything with audio 'TRUEHD 7.1' basically any content with Atmos. On the Xbox One X I have the green screen mentioned. On my Chromecast Ultra it plays fine video wise, but I can't get Dolby Atmos to work. What do you mean can't get Atmos to work? It should be converting the audio as Chromecast does not support that.
PaulW08 2 Posted February 20, 2018 Posted February 20, 2018 What do you mean can't get Atmos to work? It should be converting the audio as Chromecast does not support that. Basically I can get 5.1 to play just fine, but switching to 7.1 TRUEHD, my receiver decodes this as stereo. Through my testing it seems like the issue is related to Emby as direct playing the file from a PC, I get my receiver to recognize Atmos just fine. I'm not 100% certain that Chromecast Ultra supports Atmos, but am pretty sure it does based on my research.
