loomes 40 Posted May 13, 2017 Posted May 13, 2017 (edited) Problem solved, sorry it was my fault In the mkv files they dont work the header information for htab or hsbs are not exist. I added this and all is working. I have some 3d mkv movies, in hsbs and htab. I have set the 3d Setting for every movie manually in Emby. This works fine. Now in Kodi (tested with SPMC16 and actual Kodi17.1 with Emby 1.3.48 Addon) when the Emby Database initialize all 3d movies are correctly added. Kodi shows a 3d Marker. When i play a 3d video with direct path all is working fine but when i play over http from outside my internal network some 3d movies play correctly and some not. When the 3d detection not working when i play the video and i stop it the 3d marker in kodi is gone and i manually must refresh this movie to get it back. Kodi is configured to play 3d files in 2d mode but this wont work when i play over http and the 3d detection is not working on some files and i see the movie at is is in htab or hsbs. I have no idea why some movies work and other not. With direct Play (smb path) the 3d detection on playback works on all movies. Edited May 13, 2017 by loomes
