pgriffith 88 Posted May 13, 2017 Posted May 13, 2017 Hi all I'm using ET with a genuine MS MCE remote and all works fine.... except. How the hell do I get back to the home screen without having to use back several times, is there a key on the remote that is supposed to perform that function ? I can only assume yes, as it would ridiculous to not have that function as standard. Cheers
blade005 185 Posted May 13, 2017 Posted May 13, 2017 Hi all I'm using ET with a genuine MS MCE remote and all works fine.... except. How the hell do I get back to the home screen without having to use back several times, is there a key on the remote that is supposed to perform that function ? I can only assume yes, as it would ridiculous to not have that function as standard. Cheers No dedicated button on MCE Remote for HOME in Emby Theater. However, you can use the UP button to get to your USER ICON in upper right corner from any ET screen and then select HOME to pop back without multiple BACK selections.
pgriffith 88 Posted May 14, 2017 Author Posted May 14, 2017 Ah ok, I might try remapping one of the unused buttons to the 'home' key then.
