mpearon 7 Posted May 11, 2017 Posted May 11, 2017 I absolutely love the autoplay feature, and the fact that I can cancel it - but I don't think that it should abort the playback of the current episode. Instead, I think it should abort the auto advancement and dispose the banner, returning to the episode selection screen - behaving as if Autoplay was not enabled. Thank you guys for all of your hard work! The product is phenemonal! /mp
mpearon 7 Posted May 11, 2017 Author Posted May 11, 2017 @@ebr I'm not at home, so I can't be 110% sure (and my memory isn't awesome), but I think the button is labeled Cancel.
mpearon 7 Posted May 12, 2017 Author Posted May 12, 2017 @@ebr I confirmed that. The button is labeled "Cancel".
mpearon 7 Posted May 12, 2017 Author Posted May 12, 2017 @@ebr Thank you, sir. I do still think it would be nice to have a button with "Abort Autoplay" functionality. I don't think that there has ever been a case where I have wanted the current episode playback to terminate when I hit the current button (labeled "Cancel"). Instead, it should finish the current episode and then return to the episode selection screen.
ebr 16335 Posted May 12, 2017 Posted May 12, 2017 Typically, by the time that pops up, you are into the credits so stopping the current episode right there makes the most sense (as opposed to waiting out the credits). I know some shows run right to the end but this is not typical.
corey 317 Posted May 14, 2017 Posted May 14, 2017 Thanks. That is incorrect. It should say "Stop". @@ebr I've created a PR for this.
kaithar 0 Posted December 7, 2017 Posted December 7, 2017 Typically, by the time that pops up, you are into the credits so stopping the current episode right there makes the most sense (as opposed to waiting out the credits). I know some shows run right to the end but this is not typical. Unless you're watching one of the many many shows with after credits segments or previews that continue to the very end of the file.
ebr 16335 Posted December 7, 2017 Posted December 7, 2017 Unless you're watching one of the many many shows with after credits segments or previews that continue to the very end of the file. So then all you have to do is dismiss the up next overlay with the Menu button...
kaithar 0 Posted December 8, 2017 Posted December 8, 2017 So then all you have to do is dismiss the up next overlay with the Menu button... Well the problem I'm actually having is that I want to have autoplay on most of the time but when I want to prevent it from advancing I don't want to stop it early. I can dismiss the overlay to continue watching the credits and post-credits but cancelling the autoplay is harder. I posted mostly to support the case that watching to the very end isn't that unusual.
ebr 16335 Posted December 8, 2017 Posted December 8, 2017 ...but cancelling the autoplay is harder. Can't you just back out of the video when it ends?
kaithar 0 Posted December 8, 2017 Posted December 8, 2017 Can't you just back out of the video when it ends? Well yes, but that has problems... you have to back out early enough to stop it auto playing anyway which means cutting the video off early.
ebr 16335 Posted December 9, 2017 Posted December 9, 2017 Well yes, but that has problems... you have to back out early enough to stop it auto playing anyway which means cutting the video off early. No you don't. Just back out whenever. Even if it is right after the next one starts, everything will still be fine and the next episode will be the proper one.
kaithar 0 Posted December 9, 2017 Posted December 9, 2017 No you don't. Just back out whenever. Even if it is right after the next one starts, everything will still be fine and the next episode will be the proper one. The point is that I don't want the next one to start playing
