sstt671 1 Posted May 8, 2017 Posted May 8, 2017 Hello, I am not able to setup SSL on my emby server hosted on QNAP TS-251+. Server details: QNAP TS-251+ Firmware v4.3.3 Emby v3.2.14 Qmono v4.6.2.7 (64bit) When I supply my own ssl cert with .pfx, I can connect via http but not https. Port forwarding is done correctly. Also, if I do not supply my own cert then connect via https works fine with warning. Here is the log snippet: 2017-05-08 14:46:32.9377 Error App: Error loading cert from /*****/SSLcertificate.pfx *** Error Report *** Version: 3.2.14.0 Command line: /*****/.qpkg/Emby/Emby/MediaBrowser.Server.Mono.exe Operating system: Unix 4.2.8.0 64-Bit OS: True 64-Bit Process: True Mono: 4.6.2 (Stable 4.6.2.7/08fd525 mercredi 23 novembre 2016, 17:45:54 (UTC+0100)) Processor count: 4 Program data path: /*****/.qpkg/Emby/Emby/ProgramData-Server Application directory: /*****/.qpkg/Emby/Emby System.Security.Cryptography.CryptographicException: Unable to decode certificate. ---> System.Security.Cryptography.CryptographicException: Input data cannot be coded as a valid certificate. ---> System.Security.Cryptography.CryptographicException: Input data cannot be coded as a valid certificate. at Mono.Security.X509.X509Certificate.Parse (System.Byte[] data) [0x00041] in <1d0bb82c94e7435eb09324cf5ef20e36>:0 --- End of inner exception stack trace --- Any suggestions? Thanks,
Luke 42239 Posted May 8, 2017 Posted May 8, 2017 Interesting. We have advised going forward that mono 4.8.1 is now the recommended version. In mono 4.8 they overhauled the TLS stack so I think that may affect this. I will have to discuss the rollout of mono 4.8 with our QNAP contact. Thanks. 1
sstt671 1 Posted May 8, 2017 Author Posted May 8, 2017 I am on QMono v 4.6.2.7, do you recommend that I upgrade to v4.8 ?
sstt671 1 Posted May 8, 2017 Author Posted May 8, 2017 It is available: https://forum.qnap.com/viewtopic.php?f=214&t=109446 I will update the system and report back later. Thanks !
sstt671 1 Posted May 8, 2017 Author Posted May 8, 2017 I tired 4.8.0 and 4.8.1 both versions and got same error.
Solution sstt671 1 Posted May 10, 2017 Author Solution Posted May 10, 2017 Update: I figured out the problem(?), my original .pfx file had password. I created new one without password and now I can connect to my emby server with https. I am on Emby v3.2.15 and QMono v4.8.1.
Luke 42239 Posted May 10, 2017 Posted May 10, 2017 Thanks for the feedback ! In a future update we will allow you to specify a password for the pfx.
Swynol 375 Posted May 11, 2017 Posted May 11, 2017 Thanks for the feedback ! In a future update we will allow you to specify a password for the pfx. that's good new Luke. will the option be available for Windows Servers aswell?
