geaves 13 Posted May 8, 2017 Posted May 8, 2017 I have recently deployed omv v2 and I have installed Emby using Debian 7 for the repositories, all appears to work, movies are there, collections etc. Today I logged into Emby to update some of the images on the collections, this appeared to go well until I went back to the dashboard whereby the web gui crashed....refreshed the page and then got err_connection_refused, cleared the browser cache and tried again, same error. So through ssh I restarted the Emby service....this is the odd part, gets back to the login prompt and it continues with this error, Error HttpClient: Error getting response from https://embydata.com/downloads/ffmpeg/linux/ffmpeg-git-20170301-64bit-static.7z I had added the latest server log as the error can be seen within the log. Many thanks. server-63629835710.txt
Luke 42245 Posted May 9, 2017 Posted May 9, 2017 hi @@geaves, please try 3.2.15 and let us know if this is any different. thanks !
geaves 13 Posted May 9, 2017 Author Posted May 9, 2017 Thanks @@Luke updated but still appears the same have attached log, and it's still the same as in first post. server-63629960719.txt
Luke 42245 Posted May 9, 2017 Posted May 9, 2017 Try removing your installed plugins and see if that makes a difference. thanks.
geaves 13 Posted May 10, 2017 Author Posted May 10, 2017 @@Luke thanks doesn't appear to make any difference, have attached another log which will show the same error. server-63629997936.txt
Luke 42245 Posted May 10, 2017 Posted May 10, 2017 What are we talking about exactly, just the error at startup?
geaves 13 Posted May 10, 2017 Author Posted May 10, 2017 This is a short version from the terminal if do I service emby-server stop, then service emby-server start Info, AuthenticationRepository, Default journal_mode for /var/lib/emby-server/data/authentication.db is wal Info, AuthenticationRepository, PRAGMA synchronous=1 . root@OMV:~# Info, HttpClient, HttpClientManager.GetTempFileResponse url: https://embydata.com/downloads/ffmpeg/linux/ffmpeg-git-201703 01-64bit-static.7z Error, HttpClient, Error getting response from https://embydata.com/downloads/ffmpeg/linux/ffmpeg-git-20170301-64bit-static.7z *** Error Report *** Version: 3.2.15.0 Command line: /usr/lib/emby-server/bin/MediaBrowser.Server.Mono.exe -programdata /var/lib/emby-server -ffprobe /usr/bin/ffprob e -restartpath /usr/lib/emby-server/restart.sh Operating system: Unix 3.2.0.4 64-Bit OS: True 64-Bit Process: True Mono: 4.6.2 (Stable 4.6.2.7/08fd525 Wed Mar 15 20:19:10 UTC 2017) Processor count: 4 Program data path: /var/lib/emby-server Application directory: /usr/lib/emby-server/bin System.Net.WebException: Error: SecureChannelFailure (The authentication or decryption has failed.) ---> System.IO.IOException : The authentication or decryption has failed. ---> System.IO.IOException: The authentication or decryption has failed. ---> Mono.Secu rity.Protocol.Tls.TlsException: The authentication or decryption has failed. at Mono.Security.Protocol.Tls.RecordProtocol.EndReceiveRecord (System.IAsyncResult asyncResult) [0x00040] in <1d0bb82c94e743 5eb09324cf5ef20e36>:0 Finishes on these 2 lines Info, App, Entry point completed: Emby.Server.Core.EntryPoints.ExternalPortForwarding. Duration: 9.9E-05 seconds Info, App, All entry points have started It then hangs, so the only way to get back to the prompt is Ctrl C then exit to close the session. But why is it attempting to download Ffmpeg? when I have downloaded the recommended version and pointed emby to the location with custom install.
Luke 42245 Posted May 11, 2017 Posted May 11, 2017 It doesn't look like you've configured ffmpeg. Look at the command line used to launch emby. It is specifying only an ffprobe path, but no ffmpeg. Both are needed. Or, they can be omitted from the command line and configured in the web interface.
geaves 13 Posted May 11, 2017 Author Posted May 11, 2017 It doesn't look like you've configured ffmpeg. Look at the command line used to launch emby. It is specifying only an ffprobe path, but no ffmpeg. Both are needed. Or, they can be omitted from the command line and configured in the web interface. I downloaded the recommended version added it to /etc and pointed to the path after selecting custom so it should point /etc/FFmpeg. I did this twice, because the first time I selected installed version and pointed to the same path.....(multitasking was never my thing, and I was on a support call the first time around) Looks like another install then unless there is a conf file or something I can change.
Luke 42245 Posted May 11, 2017 Posted May 11, 2017 You still need to fix the bad command line that is starting the emby process.
geaves 13 Posted May 11, 2017 Author Posted May 11, 2017 Ok totally clean install, no addons, custom path to FFmpeg with emby having read access, still the same. server-63630139522.txt
Luke 42245 Posted May 12, 2017 Posted May 12, 2017 Ok, there is an errant command line param, we need to get that removed from the debian package. We'll be issuing an update for that. thanks.
