FordGT90Concept 103 Posted April 14, 2018 Author Posted April 14, 2018 (edited) Updated to .68, tested, no change from before (message about audio/video not working). Enabled direct stream, worked. Same channel both times. Edited April 14, 2018 by FordGT90Concept
FordGT90Concept 103 Posted August 13, 2018 Author Posted August 13, 2018 Live TV on Shield is quite terrible. The aforementioned audio desync is still present. The initial pause can now last upwards of a minute and it can happen again several minutes after it does the intitial pause. In terms of trick play, only pause/resume works. If you try to jump forward or backwards, there's an excellent chance the stream will simply freeze. Server is on 3.6.0.2 beta and I'm concerned that it hasn't seen an update in a long time (especially the retroactive timer patch on the 3.5.2 branch).
ebr 16337 Posted August 13, 2018 Posted August 13, 2018 This is not my experience at all so it is very difficult to diagnose. You are streaming in seek mode, correct?
FordGT90Concept 103 Posted August 13, 2018 Author Posted August 13, 2018 I assume so. All the settings are default.
ebr 16337 Posted August 13, 2018 Posted August 13, 2018 Does the app say it is playing direct or remuxing?
FordGT90Concept 103 Posted August 14, 2018 Author Posted August 14, 2018 Has to be remuxing. The Xbox One S has no problems doing live TV. They're connected to the same switch.
Luke 42245 Posted August 14, 2018 Posted August 14, 2018 There hasn't been a beta server in a while due to this: https://emby.media/community/index.php?/topic/61079-3603-db-changes/ 1
