FordGT90Concept 103 Posted June 1, 2017 Author Posted June 1, 2017 Just to be clear, the when I say pixelation, I mean what is observed in the original post video (squares turn into giant pixels over areas of the display). The lack of deinterlacing is what is in that picture I posted a ways back where there's horizontal lines. That said, I wasn't really looking for the deinterlacing issue in my last post. I was looking at the four points in the original post. All three were largely fixed while time to tune is worse (which is inevitable because of DVR and waiting for sync).
mwongjay 74 Posted June 1, 2017 Posted June 1, 2017 Just to be clear, the when I say pixelation, I mean what is observed in the original post video (squares turn into giant pixels over areas of the display). The lack of deinterlacing is what is in that picture I posted a ways back where there's horizontal lines. That said, I wasn't really looking for the deinterlacing issue in my last post. I was looking at the four points in the original post. All three were largely fixed while time to tune is worse (which is inevitable because of DVR and waiting for sync). Ah I see. Ok. Well deinterlacing (or lack thereof) was really my main focus. The time to tune is not a huge issue for me, but that's because it's always been under 7 seconds which for me is tolerable. I do not have or ever had the pixelation issues you were experiencing.
FordGT90Concept 103 Posted June 1, 2017 Author Posted June 1, 2017 I've only noticed the interlacing problem on Windows. I don't think I've ever seen it on Android TV.
FordGT90Concept 103 Posted June 4, 2017 Author Posted June 4, 2017 Observed the first problem since the updates today. -Android TV couldn't tune (spinny wheel, KTIV repeatedly) and then it would stop with a message saying no tuners available. -Restarted device, still couldn't tune. -Used Surface 2 to check status of Tuners via Emby, 6 of 6 tuners available. -Tried to tune via Surface 2 browser, it's like the request was completely ignored when clicking play. -Restarted Emby Server. -Problem fixed. I attached all the server logs I have because I don't know how far back this issue goes. About 5-10 minutes from posting this (5:30pm-ish) is when the above sequence occurred. Both Server and Android TV are current beta. logs.zip
mwongjay 74 Posted June 5, 2017 Posted June 5, 2017 @@ebr @@Luke Any progress on updating the parameters for deinterlacing with yadif?
Luke 42245 Posted June 5, 2017 Posted June 5, 2017 We already deinterlace when ffmpeg detects the video stream as being interlaced.
mwongjay 74 Posted June 5, 2017 Posted June 5, 2017 We already deinterlace when ffmpeg detects the video stream as being interlaced. Is it possible there was a regression? Based on my logs it doesn't appear to be deinterlacing live tv. This post examines the issue further https://emby.media/community/index.php?/topic/47389-live-tv-initial-pause-pixelation-and-long-pauses/?p=454857
ebr 16337 Posted June 5, 2017 Posted June 5, 2017 Is it possible there was a regression? Based on my logs it doesn't appear to be deinterlacing live tv. This post examines the issue further https://emby.media/community/index.php?/topic/47389-live-tv-initial-pause-pixelation-and-long-pauses/?p=454857 Are you using the production or beta version of the Android TV app?
mwongjay 74 Posted June 5, 2017 Posted June 5, 2017 Are you using the production or beta version of the Android TV app? Beta
ebr 16337 Posted June 5, 2017 Posted June 5, 2017 Can I please see the full ffmpeg log referenced above? Or just create a new one and, if you do that, also send a log from the app. Thanks.
mwongjay 74 Posted June 7, 2017 Posted June 7, 2017 Can I please see the full ffmpeg log referenced above? Or just create a new one and, if you do that, also send a log from the app. Thanks. Sent logs at 8:19PM. User mjw06d. Attached is the transcoding log.
ebr 16337 Posted June 7, 2017 Posted June 7, 2017 Sent logs at 8:19PM. User mjw06d. Attached is the transcoding log. Thanks. I believe this was an issue on the server that is fixed in the current server beta.
mwongjay 74 Posted June 7, 2017 Posted June 7, 2017 Thanks. I believe this was an issue on the server that is fixed in the current server beta. Awesome. Looking forward to it. Unfortunately, I don't run the beta version of the server so I'll report back when the next release drops.
FordGT90Concept 103 Posted June 7, 2017 Author Posted June 7, 2017 Is there a beta version >3.2.19.0 with this fix because if there is, that's the newest I have and I still see the lack of deinterlacing.
mwongjay 74 Posted June 7, 2017 Posted June 7, 2017 Is there a beta version >3.2.19.0 with this fix because if there is, that's the newest I have and I still see the lack of deinterlacing. 3.2.19.5 fixes it. I checked the commits in github.
FordGT90Concept 103 Posted June 7, 2017 Author Posted June 7, 2017 Uh, I just checked, Emby Server is still saying 3.2.19.0 is the latest. Going to have to force it to install then...
FordGT90Concept 103 Posted June 7, 2017 Author Posted June 7, 2017 Well, updating was a bad idea. 2/3 times, Android TV said "Too many errors" trying to tune. The one time it did tune probably took a minute. I sent logs from it twice: first time was after it worked for a bit, second time was after it gave the "too many errors" message. Server logs attached. logs.zip
mwongjay 74 Posted June 7, 2017 Posted June 7, 2017 Well, updating was a bad idea. 2/3 times, Android TV said "Too many errors" trying to tune. The one time it did tune probably took a minute. I sent logs from it twice: first time was after it worked for a bit, second time was after it gave the "too many errors" message. Server logs attached. Are you using hardware accelerated transcoding?
ebr 16337 Posted June 8, 2017 Posted June 8, 2017 Well, updating was a bad idea. 2/3 times, Android TV said "Too many errors" trying to tune. The one time it did tune probably took a minute. I sent logs from it twice: first time was after it worked for a bit, second time was after it gave the "too many errors" message. Server logs attached. Hi. Can you please provide the information requested in the instructions on sending a log from the app? It is next to impossible for me to identify the right one without this info. Thanks! Exactly what you were doing and what happened. Include the name of whatever you played if it is a playback problem The time you sent the log The name of the Emby user on the local server that was logged in at the time
FordGT90Concept 103 Posted June 8, 2017 Author Posted June 8, 2017 (edited) It was trying to tune to KCAU 9.1 which had Dr. Phil on at the time. Time should match about when I posted it (5pm central). I think it was Lynn, if not Lynn, Lee. I think this particular tuning issue is specific to Android TV because I'm watching the Comey testifying now through my computer and the Windows Store app and it worked perfectly. Edited June 8, 2017 by FordGT90Concept
ebr 16337 Posted June 8, 2017 Posted June 8, 2017 It was trying to tune to KCAU 9.1 which had Dr. Phil on at the time. Time should match about when I posted it (5pm central). I think it was Lynn, if not Lynn, Lee. I think this particular tuning issue is specific to Android TV because I'm watching the Comey testifying now through my computer and the Windows Store app and it worked perfectly. Thanks, it looks like the attempt to get the stream simply timed out.
FordGT90Concept 103 Posted June 8, 2017 Author Posted June 8, 2017 (edited) What I saw on the screen was the program info on the bottom popped up as normal after about 10 seconds and then went away. About a minute later, that info would pulse repeatedly then go away. Finally, it would close it down and say it gave up. 2 out of 3 times I tried, this happened. The one time it worked, I think it took about a minute to tune (ridiculously long). This problem didn't exist on 3.2.19.0 and, as far as I can tell, doesn't exist in the server either. Edited June 8, 2017 by FordGT90Concept
ebr 16337 Posted June 8, 2017 Posted June 8, 2017 Yes, I see it trying to get the stream from the server three times and then giving up. Each time, from the app's perspective, it is simply not able to load the stream. Here is one of the attempts which covers a span of about 30 seconds while it was trying to read the stream. 06-07 16:53:27.439 2760 2760 I System.out: internalError [8.30, loadError] 06-07 16:53:35.447 2760 2760 I System.out: internalError [16.31, loadError] 06-07 16:53:44.456 2760 2760 I System.out: internalError [25.31, loadError] 06-07 16:53:54.466 2760 2760 I System.out: internalError [35.32, loadError] 06-07 16:53:54.472 2760 3022 E ExoPlayerImplInternal: Source error. Have you tried this same channel at a different time?
