Luke 42213 Posted November 4, 2017 Posted November 4, 2017 As far as the remote access goes, i would suggest checking out our Connection Troubleshooter. Please try the steps listed there and let us know exactly what succeeds and what fails. thanks !
nagetech 70 Posted November 4, 2017 Posted November 4, 2017 @@Luke Hey Luke do you think it would be possible to implement something in the admin panel to help maintain the SQL database? Might be useful to users with long standing installs to make sure the database is as lean and mean as possible. 3
bozrdnag 75 Posted December 20, 2017 Posted December 20, 2017 I had the same problem with emby-server on linux. Rather than wiping out the db and starting over I chose a different approach: systemctl stop emby-server sqlite3 /var/lib/emby-server/data/library.db "VACUUM" sqlite3 /var/lib/emby-server/data/library.db "ANALYZE" sqlite3 /var/lib/emby-server/data/library.db "REINDEX" systemctl start emby-sever I am running Emby Server in a Docker container on unRAID and I would like to do this. The problem is that when I run the first line I get an error saying: systemctl: command not found Can anyone tell me how to stop the emby-server process from the container console?
Luke 42213 Posted December 20, 2017 Posted December 20, 2017 @@Luke Hey Luke do you think it would be possible to implement something in the admin panel to help maintain the SQL database? Might be useful to users with long standing installs to make sure the database is as lean and mean as possible. It's possible, the problem is that is you will not be able to use the server at all while this is happening. We also won't be able to show a progress bar for it either. Inevitably people are going to kill the process because they don't like how long it's taking, which then means we're going to have to troubleshoot potentially corrupted databases.
MikePlanet 144 Posted December 20, 2017 Posted December 20, 2017 It's possible, the problem is that is you will not be able to use the server at all while this is happening. We also won't be able to show a progress bar for it either. Inevitably people are going to kill the process because they don't like how long it's taking, which then means we're going to have to troubleshoot potentially corrupted databases. Didn't you do such maintenance automatically in the past? It seems actually really useful - I did a compress/reindex of the library.db via sqlite explorer and it reduced the response time in the GUI from 10-20 seconds down to 1-5 seconds. So indeed it seems necessary at least for larger databases to keep the system "snappier"...
Luke 42213 Posted December 20, 2017 Posted December 20, 2017 They were actually db upgrades, which we will never do again, for similar reasons.
Luke 42213 Posted July 18, 2019 Posted July 18, 2019 I had the same problem with emby-server on linux. Rather than wiping out the db and starting over I chose a different approach: systemctl stop emby-server sqlite3 /var/lib/emby-server/data/library.db "VACUUM" sqlite3 /var/lib/emby-server/data/library.db "ANALYZE" sqlite3 /var/lib/emby-server/data/library.db "REINDEX" systemctl start emby-sever How to vacuum your emby server database: https://emby.media/community/index.php?/topic/75510-42032-vacuum-database-config-switch/ Thanks.
morpheus1 2 Posted May 3, 2020 Posted May 3, 2020 (edited) I had the same problem with emby-server on linux. Rather than wiping out the db and starting over I chose a different approach: systemctl stop emby-server sqlite3 /var/lib/emby-server/data/library.db "VACUUM" sqlite3 /var/lib/emby-server/data/library.db "ANALYZE" sqlite3 /var/lib/emby-server/data/library.db "REINDEX" systemctl start emby-sever Sorry for digging this up, but is this still applicable to the current server version for linux? Edited May 3, 2020 by morpheus1
Luke 42213 Posted May 3, 2020 Posted May 3, 2020 Sorry for digging this up, but is this still applicable to the current server version for linux? This is: https://emby.media/community/index.php?/topic/75510-42032-vacuum-database-config-switch/
