d00zah 152 Posted May 7, 2017 Posted May 7, 2017 Server v3.2.14.0 (this goes back as far as I have logs) TimeLordMovies, Version=16.10.26.1413 AutoBoxSets, Version=1.1.0.6 Functionally, everything seems to work as expected, but TimeLordMovies reports one of these errors for each collection when run: 2017-05-07 09:36:57.1319 Error App: Error messing about with for 28 Days Later Collection *** Error Report *** Version: 3.2.14.0 Command line: C:\Users\[ADMINACT]\AppData\Roaming\Emby-Server\system\MediaBrowser.ServerApplication.exe -service Operating system: Microsoft Windows NT 6.1.7601 Service Pack 1 64-Bit OS: True 64-Bit Process: True Processor count: 4 Program data path: C:\Users\[ADMINACT]\AppData\Roaming\Emby-Server Application directory: C:\Users\[ADMINACT]\AppData\Roaming\Emby-Server\system System.ArgumentNullException: Value cannot be null. at MediaBrowser.Controller.Entities.Folder.GetChildren(User user, Boolean includeLinkedChildren) at MediaBrowser.Controller.Entities.Movies.BoxSet.GetChildren(User user, Boolean includeLinkedChildren) at MediaBrowser.Plugins.TimeLordMovies.ScheduledTasks.SetAirDateTask.<Execute>d__10.MoveNext() System.ArgumentNullException at MediaBrowser.Controller.Entities.Folder.GetChildren(User user, Boolean includeLinkedChildren) at MediaBrowser.Controller.Entities.Movies.BoxSet.GetChildren(User user, Boolean includeLinkedChildren) at MediaBrowser.Plugins.TimeLordMovies.ScheduledTasks.SetAirDateTask.<Execute>d__10.MoveNext() 1
mediacowboy 438 Posted May 23, 2017 Posted May 23, 2017 (edited) Seeing this as well. @@BeppoMonkeyBoy, any idea's? What made me start looking is the date added on movies is being changed to premier date. Edited May 23, 2017 by mediacowboy
d00zah 152 Posted May 23, 2017 Author Posted May 23, 2017 (edited) Restarted server to trigger 'Change Movie date added to original Premier date' startup task before submission... Edit: replaced log Edited May 23, 2017 by d00zah
mediacowboy 438 Posted May 23, 2017 Posted May 23, 2017 (edited) I have done the same. Restarted the server and ran a fresh TimeLord Movie task. server-63631155369.txt Edited May 24, 2017 by mediacowboy
Sven 136 Posted May 24, 2017 Posted May 24, 2017 (edited) As far as I can see in the logs, It's indeed something with the date. But I don't have the source for this project. So I can't check it... And @@BeppoMonkeyBoy is not that active anymore.. Edited May 24, 2017 by Sven
Luke 42252 Posted May 24, 2017 Posted May 24, 2017 As far as I can see in the logs, It's indeed something with the date. But I don't have the source for this project. So I can't check it... And @@BeppoMonkeyBoy is not that active anymore.. He was on here 8 days ago. I would try sending him a PM.
Sven 136 Posted May 24, 2017 Posted May 24, 2017 @@Luke Yeah he will also receive the mentions. So hopefully he will react on that.
