Lee 212 Posted May 18, 2017 Author Posted May 18, 2017 @@Luke I've noticed lately the start up update process takes ages now.. Sometimes think it's not going to start. Maybe a checking for updates screen? Or a setting for weekly intervals on update checks? Also getting a lot of error messages upon install/upgrade.. Thinking could this be a factor with my playback issues..?
Luke 42243 Posted May 18, 2017 Posted May 18, 2017 @@Luke I've noticed lately the start up update process takes ages now.. Sometimes think it's not going to start. Maybe a checking for updates screen? Or a setting for weekly intervals on update checks? Also getting a lot of error messages upon install/upgrade.. Thinking could this be a factor with my playback issues..? that is only when it is unpacking a new update, and yes, we should have a loading screen for that. it is important to try and provide useful and detailed information. you say there are messages, what are they?
Lee 212 Posted May 18, 2017 Author Posted May 18, 2017 I've no idea what else I can do at this point.. I've sent all my logs in.. Can you advise on how I get the old version working because atm I can't watch anything without going to a web browser which is garbage
Luke 42243 Posted May 18, 2017 Posted May 18, 2017 What you can do is provide more detail. What messages are you referring to? What about the listing of your settings that we asked for earlier? thanks !
Guest asrequested Posted May 18, 2017 Posted May 18, 2017 Lee, if it were me, I would reestablish a baseline. While sitting at the machine (not operating remotely), I would completely remove theater. Reboot. Go to the website and reinstall. Start the app, run it for a minute, not using it or changing anything. Close it, wait a minute, restart. Wait until the UI settles. Don't change any settings, and play something. Have your screenshot software open, to capture any notifications. Post on here screenshots and details of what specifically happened if you encounter any problems? I think we need to start from the beginning and forget what has happened up this point. We should chart each stage of testing, so we can see what, if anything needs to be adjusted.
Luke 42243 Posted May 18, 2017 Posted May 18, 2017 additionally are you doing your testing over remote desktop?
Lee 212 Posted May 19, 2017 Author Posted May 19, 2017 @ Sound advice. I had already had a bit of a go at this last night. I suspect I'm not getting glen installs/upgrades... I removed all traces and reinstalled last night. 2.7.1 There were far more video switches than before in 2.7.1 So I played a hevc video (most problematic) with baseline/standard settings.. No dice Changed audio to pass through and speaker environment to 5.1 No change Changed video to hw acc- auto No change Changed to windows d3d Marked improvement but still stuttering So is intel quicksync coming to video as I noted ATI and NVidia hw acceleration is there? So atm I'm still stuck with 1080p 60mbps playback thru browser or it's unwatchable. It says direct playback - but I think it's transcoding as waves and crowds of people made the stutter markedly worse? oh and @@Luke no the fps and bandwidth isn't good enough to use rdp is it? I'm only remoting in for logs
Lee 212 Posted May 19, 2017 Author Posted May 19, 2017 Note *clean installs/upgrades... Stupid autocorrects
Lee 212 Posted May 19, 2017 Author Posted May 19, 2017 Also worth adding I didn't catch the exact fault window when it happened.. Was a few builds ago now but it was to do with access to appdata roaming..
Lee 212 Posted May 19, 2017 Author Posted May 19, 2017 http://www.intel.com/content/dam/www/public/us/en/documents/product-briefs/atom-x5-processor-z8350-product-brief.pdf it does appear the atom supports quicksync
Guest asrequested Posted May 19, 2017 Posted May 19, 2017 OK. So reset all settings back to default, and change hardware acceleration to auto copy back. And test.
Luke 42243 Posted May 19, 2017 Posted May 19, 2017 by default with standalone mpv, hwdec=no, so maybe he should keep hardware acceleration at no since he said standalone mpv worked well.
Lee 212 Posted May 19, 2017 Author Posted May 19, 2017 i did notice a few times I forgot to mention the theme video was playing instead of the episode.. got this screengrab just... maybe its playing two videos at a time ??? although the server doesn't say so
Luke 42243 Posted May 19, 2017 Posted May 19, 2017 auto copyback doesn't work neither does none What does doesn't work mean? is it failing to play?
Lee 212 Posted May 19, 2017 Author Posted May 19, 2017 it will play with any of the hw acc profiles.. just stutters haven't tried cuda as its not nvidia so suspect that won't work.. @ pulling what from the internet? the theme? i have no idea.. i've no plugins installed
Lee 212 Posted May 19, 2017 Author Posted May 19, 2017 hmmm... it won't the control panel spazzes and reverts back to 59hz
Lee 212 Posted May 19, 2017 Author Posted May 19, 2017 battery had died on my mousepad.. that's why I couldn't choose another refresh rate... 23hz sorted it.. frame rate switching not working???
Luke 42243 Posted May 19, 2017 Posted May 19, 2017 Can we just talk about basic playback right now since that seems to be where your issue is? thanks.
