Crestj 68 Posted May 5, 2017 Posted May 5, 2017 Time has come to retire my Emby Server and it's wheezy AMD Turion II CPU that quite frankly should have died years ago. I've been searching through the wiki's and forums but have yet to find a guide to migrate your entire Emby Server setup to a new installation. I back it up regularly using the "Emby Backup" plugin but am not sure the approved method to use this to get a new installation running with the same config. Anyone know a guide I can read or have tips on what to do and, more importantly, what NOT to do?
Solution Luke 42200 Posted May 5, 2017 Solution Posted May 5, 2017 Hi, you can do it right from the web UI. Just open the configuration screen of the backup plugin. Let us know if this helps. Thanks. 1
Crestj 68 Posted May 5, 2017 Author Posted May 5, 2017 Lol I didn't realise you just click the backup listed and it has all the restore options! D'oh! Cheers Luke Sent from my A0001 using Tapatalk 1
Happy2Play 9802 Posted May 5, 2017 Posted May 5, 2017 Well you have a new installation, so install plugin, point to backup location and select the restore date you want. 1
