Jdiesel 1435 Posted May 5, 2017 Posted May 5, 2017 I have noticed that the homescreen is not refreshing to show recently added media. New media is added to the server and shows up in the web app but they only way to get the views to change on the Roku homescreen is to exit the app and re-open it. I believe if left long enough it will update on its own but it would be nice to have it update instantly like the web app.
Jdiesel 1435 Posted May 14, 2017 Author Posted May 14, 2017 Anyone else experiencing this? I often have to close the app and reopen it to get any thing on my homescreen to refresh.
ebr 16335 Posted May 15, 2017 Posted May 15, 2017 I think navigating to some content and then coming back should refresh in most instances but probably not all. The plumbing was not in place for the server to talk to the Roku for library changes but that is going in now so it will eventually be better.
Jdiesel 1435 Posted May 22, 2017 Author Posted May 22, 2017 So it appears that the landing pages do refresh when you to them but the main home screen does not. Only exiting and opening the app causing the home screen to refresh.
ifignella 12 Posted May 22, 2017 Posted May 22, 2017 (edited) I found an enter/exit spot to refresh the home page a while back, but I can't remember what it is. Try clicking on settings at the bottom of home page and back out, maybe that was it. Edited May 22, 2017 by ifignella
Jdiesel 1435 Posted May 26, 2017 Author Posted May 26, 2017 Any update on this? Even if it isn't an instant refresh but is run as a scheduled task.
ebr 16335 Posted May 26, 2017 Posted May 26, 2017 To accomplish this we needed to make changes to both server and app. Should be coming soon. Thanks. 1
