moviefan
I've been having some issues over the past week with the HTTPS service not working consistently.  Especially after a system restart.
Works over HTTP just fine.  But HTTPS completely broken for some period of time after the server restarts.
Server log attached.
Edited by moviefan
Swynol
when it stops working can you access it internally using https? anything else using port 5555?
moviefan
No, when it's not working it doesn't even return the SSL certificate on port 5555.
Seems like the port is open because I dont get an immediate error but nothing ever displays.
Swynol
Sounds strange. I've never had an issue with the cert not returning. Are you using emby server on Windows? If so you can try to move the cert to the emby server install folder invade it's a Windows permissions issue. Also try it with Embys own self signed cert on port 5555. See if you get the same issue. Can rule out any cert issues.
Sent from my iPhone using Tapatalk
