jhs 1 Posted May 3, 2017 Posted May 3, 2017 Hi! It seems that emby won't allow me to use EAC3 or AC3 with my Chromecast Ultra. Is this intended behaviour? It should be able to passthrough it to my reciever. Best RegardsJonatan!
Luke 42243 Posted May 3, 2017 Posted May 3, 2017 Hi @@jhs, it sure does ! We use a google cast api on the receiver that tells us whether ac3 is supported by your audio equipment or not. Best thing to do is discuss an example by providing the information requested in how to report a media playback issue. thanks !
jhs 1 Posted May 3, 2017 Author Posted May 3, 2017 (edited) Hello, and thank you for your quick reply. I tried playing an EAC3 file, but it only plays AC3, so my original post is a bit wrong. My mistake. But, it still removes the "E" when it can play EAC3 just fine. I have attached the server logs, and the "remux" log from the file. I hope you can see the mistake, when looking through the logs. Best regards, and a huge thankyou for Emby, i use this software daily, and it has never let me down! Jonatan Edited May 4, 2017 by jhs
Solution Luke 42243 Posted May 4, 2017 Solution Posted May 4, 2017 hi @@jhs, I've pushed an update to our chromecast receiver. Please reboot your chromecast device and try again. Let me know if it direct plays now. thanks ! 1
jhs 1 Posted May 4, 2017 Author Posted May 4, 2017 @@Luke You are the best! It works! Are there any way I can show my appreciation for your hard work? Best regards Jonatan
Luke 42243 Posted May 4, 2017 Posted May 4, 2017 Thanks for the feedback ! Yes you can support the team with Emby Premiere: https://emby.media/premiere.html Thanks !
jhs 1 Posted May 4, 2017 Author Posted May 4, 2017 Thank you again! I have subscribed! Keep up the good work!
