Crash on Start After Crash During Library Scan
Trizzone52
Edit: Managed to solve repeated crashing by restarting server. Still don't understand issue, but no longer seeing those crashes I listed below, down to just a libmagick error. Posted it below.
Maybe delete this thread?
2017-05-03 15:22:41.6196 Error ImageProcessor: Error encoding image
	*** Error Report ***
	Version: 3.2.13.11
	Command line: /usr/lib/emby-server/bin/MediaBrowser.Server.Mono.exe -programdata /var/lib/emby-server -restartpath /usr/lib/emby-server/restart.sh
	Operating system: Unix 3.16.0.4
	64-Bit OS: True
	64-Bit Process: True
	Mono: 4.6.2 (Stable 4.6.2.7/08fd525 Mon Nov 28 20:21:32 UTC 2016)
	Processor count: 4
	Program data path: /var/lib/emby-server
	Application directory: /usr/lib/emby-server/bin
	ImageMagickSharp.WandException
	  at ImageMagickSharp.WandCore`1[T].CheckError (System.Boolean status) [0x00009] in <256b1c1ea9f54fe39d5f58f7aa82a335>:0
	  at ImageMagickSharp.ImageWand+<>c__DisplayClass16.<ScaleImage>b__15 () [0x0002c] in <256b1c1ea9f54fe39d5f58f7aa82a335>:0
	  at ImageMagickSharp.ImageWand.ActivateImageWand[T] (System.Func`1[TResult] wandAction) [0x00011] in <256b1c1ea9f54fe39d5f58f7aa82a335>:0
	  at ImageMagickSharp.ImageWand.ScaleImage (System.Int32 width, System.Int32 height) [0x0001b] in <256b1c1ea9f54fe39d5f58f7aa82a335>:0
	  at Emby.Drawing.ImageMagick.ImageMagickEncoder.ScaleImage (ImageMagickSharp.MagickWand wand, System.Int32 width, System.Int32 height, System.Int32 blur) [0x00028] in <0aef7336578543f48249acd7e704c545>:0
	  at Emby.Drawing.ImageMagick.ImageMagickEncoder.EncodeImage (System.String inputPath, System.String outputPath, System.Boolean autoOrient, System.Int32 width, System.Int32 height, System.Int32 quality, MediaBrowser.Controller.Drawing.ImageProcessingOptions options, MediaBrowser.Model.Drawing.ImageFormat selectedOutputFormat) [0x00050] in <0aef7336578543f48249acd7e704c545>:0
	  at Emby.Drawing.ImageProcessor+<ProcessImage>c__async1.MoveNext () [0x00540] in <ee8aacb835434673bf9fe04c4d7d5709>:0
Original Post:
Hi all,
I've got emby installed on a debian server. I spent a couple hours trying to figure out how to auto generate primary images for folders in a home video & photos gallery (another problem i'm having), and after:
1) setting a couple folders to refresh their metadata and images
2) starting a media library scan
emby crashed, and now I can't get it to start.
I was able to discover that emby has been creating "unhandled" logs that I believe are created by these crashes.  I was also able to get into the regular emby logs and find out there are a whole host of errors being generated. Unfortuately, I am not experienced enough to have any idea what exactly is the issue. Would someone give the two linked text files a look and give feedback on whether these errors are possible causes of the crashes I've been having?
Thanks.
"Unhandled" log:
https://pastebin.com/KaaKbHpC
Recurring error found in standard log:
https://pastebin.com/aeCNHdKh
(Note: I've also had regular pauses during scanning that would clear after a time, as if there's a couple files in my library that emby can't process but spends a while trying every scan. Has been the case since install. These errors may or may not be related this instead.)
Log.txt
Edited by Trizzone52
