Dizzy49 99 Posted May 2, 2017 Posted May 2, 2017 I have quite a few videos, and about half of them have additional audio tracks, and probably 3/4 of them have subtitles. I am looking for a tool/script that can process them in bulk and can handle my folder structures. Folder Structure for Movies: Root Movie Folder |__Movie Title (Folder) |__Video Files Folder Stucture for TV Shows: |__Root TV Folder |__TV Series Title (Folder) |__Season X (Folder) |__Video Files I think just running the tool/script in the root folder recursively and having it process every video it finds should work. PROCESSING If Only 1 Audio Track and No Subtitles = Skip Video File [ Important so that it doesn't process files it doesn't need to ] If More than 1 Audio Track = Look for English Track(s), remove all others * If unable to locate English track(s), do not remove any [ Important in case audio tracks are not labeled properly ] * If English track(s) exist, remove all Subtitles [ Theory: If English track exists, I shouldn't need any subtitles ] * If English track(s) Do NOT exist, look for an only keep English subtitles and remove the rest - If unable to determine if English subtitles exist, do not remove any subtitles CONCERNS Subtitles will be lost for foreign parts of an English video. They SHOULD be hardcoded in the video track, but aren't always. Needs to be able to handle older videos, as well as newer ones using x265/HEVC Concerned that messing with the audio and remuxxing will screw up audio sync for the videos. WISH LIST Ability to keep only the best audio track. Many videos have multiple English audio, ie DTS 5.1, and Dobly Stereo, I even have one with like 5 English tracks. A 7.1, 3x 5.1 tracks (DTS, DTS-MA, DD), and a stereo track. My receiver can handle any audio stream, so I only need the best. Ability to keep a certain track, or only tracks up to a certain level. For instance, if the FireTV can only play Stereo, DD, and DTS I don't want anything higher than that, but if it's just hooked up to a TV that only has stero speakers, I'd just want the stereo track. Track videos where it couldn't determine audio and/or subtitles and log/email/present them at the end Track before and after file sizes to determine how much space was saved throughout process
naeonline 27 Posted May 5, 2017 Posted May 5, 2017 ffmpeg is what you are looking for. ffprobe comes with it. There are versions for whichever platform you are on (linux/mac/windows...). Scripting can be done with whichever you are familiar with to pull filenames from your folder structure for processing, then pass those filenames to ffprobe for the layout of what is in your media (eg stream 0 is h264 video, stream 1 is ac3 5.1ch audio, stream 3 is vob subtitles). You'll have to parse the ffprobe output into a structure and then choose the desired streams to keep and call ffmpeg to copy those ones to the new file. ffprobe.exe -i "VideoFileNameAndPath.mkv" -hide_banner EXAMPLE OUTPUT: Input #0, matroska,webm, from 'VideoFileNameAndPath.mkv': Metadata: encoder : libmakemkv v1.10.4 (1.3.3/1.4.4) win(x64-release) Duration: 01:09:09.98, start: 0.000000, bitrate: 28123 kb/s Chapter #0:0: start 0.000000, end 131.381250 Metadata: title : Chapter 01 Chapter #0:1: start 131.381250, end 945.861583 Metadata: title : Chapter 02 Chapter #0:2: start 945.861583, end 1476.975500 Metadata: title : Chapter 03 Chapter #0:3: start 1476.975500, end 2248.579667 Metadata: title : Chapter 04 Chapter #0:4: start 2248.579667, end 3061.641917 Metadata: title : Chapter 05 Chapter #0:5: start 3061.641917, end 3554.384167 Metadata: title : Chapter 06 Chapter #0:6: start 3554.384167, end 4149.979167 Metadata: title : Chapter 07 Stream #0:0(eng): Video: h264 (High), yuv420p(tv, bt709, progressive), 1920x1080 [sAR 1:1 DAR 16:9], 23.98 fps, 23.98 tbr, 1k tbn, 47.95 tbc Metadata: BPS-eng : 24884159 DURATION-eng : 01:09:09.979166666 NUMBER_OF_FRAMES-eng: 99500 NUMBER_OF_BYTES-eng: 12908592378 SOURCE_ID-eng : 001011 _STATISTICS_WRITING_APP-eng: MakeMKV v1.10.4 win(x64-release) _STATISTICS_WRITING_DATE_UTC-eng: 2017-03-01 16:39:56 _STATISTICS_TAGS-eng: BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES SOURCE_ID Stream #0:1(eng): Audio: dts (DTS-HD MA), 48000 Hz, stereo, s16p (default) Metadata: title : Stereo BPS-eng : 1684425 DURATION-eng : 01:09:09.856000000 NUMBER_OF_FRAMES-eng: 389049 NUMBER_OF_BYTES-eng: 873765548 SOURCE_ID-eng : 001100 _STATISTICS_WRITING_APP-eng: MakeMKV v1.10.4 win(x64-release) _STATISTICS_WRITING_DATE_UTC-eng: 2017-03-01 16:39:56 _STATISTICS_TAGS-eng: BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES SOURCE_ID Stream #0:2(eng): Audio: dts (DTS), 48000 Hz, stereo, fltp, 1536 kb/s Metadata: title : Stereo BPS-eng : 1509000 DURATION-eng : 01:09:09.856000000 NUMBER_OF_FRAMES-eng: 389049 NUMBER_OF_BYTES-eng: 782766588 SOURCE_ID-eng : 001100 _STATISTICS_WRITING_APP-eng: MakeMKV v1.10.4 win(x64-release) _STATISTICS_WRITING_DATE_UTC-eng: 2017-03-01 16:39:56 _STATISTICS_TAGS-eng: BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES SOURCE_ID Stream #0:3(eng): Subtitle: hdmv_pgs_subtitle Metadata: BPS-eng : 41924 DURATION-eng : 01:08:14.945020833 NUMBER_OF_FRAMES-eng: 2732 NUMBER_OF_BYTES-eng: 21459731 SOURCE_ID-eng : 001200 _STATISTICS_WRITING_APP-eng: MakeMKV v1.10.4 win(x64-release) _STATISTICS_WRITING_DATE_UTC-eng: 2017-03-01 16:39:56 _STATISTICS_TAGS-eng: BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES SOURCE_ID So a quick breakdown of the ffprobe info, the video file has chapters, h264 video, eng DTS-HD MA, eng DTS, eng PGS subtitles. Lets say my systems can only play up to DTS but not DTS-HD MA so I choose to keep DTS only. You use the -map parameter to do this. I want streams 0(video) and 2(dts) only, leaving out the subtitle as well. how map works: -map #(input file #):#(input file stream #) -c(codec):v/a/s(video/audio/subtitle):#(stream # in output file) ffmpeg.exe -i "VideoFileNameAndPath.mkv" -map 0:0 -c:v:0 copy -map 0:2 -c:a:0 copy "OutputFileNameAndPath.mkv" In my experience, ffmpeg with these settings should preserve chapter data and metadata in the output file from the input file. Hope this helps you get started. 1
Dizzy49 99 Posted June 21, 2017 Author Posted June 21, 2017 (edited) So, I wrote a script that goes through my collection and uses ffprobe to get details on all the files. Looks like the basic format is. Stream #0:x (lang): Video/Audio/Subtitle The x can change, and the lang could change. I found several Streams missing a language though. Then it's just "Stream #0:x: Video/Audio/Subtitle" However, in all instances, there are other indicators such as Metadata that can be used to determine. I think if the data could be parsed, and check for language that it would at least resolve 90+% of my files. However, I am not smart enough to be able to write a script to do it. It took me WAY longer than it should have to write this simple batch file: for /r . %%a in (*.mkv) do ( if "%%~nxa" neq "trailer.mkv" ffprobe.exe -i "%%a" -hide_banner 2>> results.txt ) I could probably hack together a C# program to do it if I had time, which I have NONE OF while the kids are out of school... Edited June 21, 2017 by Dizzy49
Emby Tower 34 Posted June 21, 2017 Posted June 21, 2017 (edited) You could try MKV Optimizer: https://www.htpc-tools.de/mkv-optimizer/ (German) The application has English and German language support! Edited June 21, 2017 by Emby Tower
pir8radio 1313 Posted June 21, 2017 Posted June 21, 2017 I use MKV toolnix: https://mkvtoolnix.download/ It's painless.
nagetech 70 Posted June 21, 2017 Posted June 21, 2017 I use MKV toolnix: https://mkvtoolnix.download/ It's painless. I've never used that program before and I'd be interested in doing what the OP wanted to do. Does that program have a "monitor" feature where it keeps an eye on a directory and automatically "strips" all foreign languages out of a file?
pir8radio 1313 Posted June 22, 2017 Posted June 22, 2017 I've never used that program before and I'd be interested in doing what the OP wanted to do. Does that program have a "monitor" feature where it keeps an eye on a directory and automatically "strips" all foreign languages out of a file? I'm not sure if you can do automated stuff with it, I have a pretty low volume of videos, so I use it as needed.
ulrick65 30 Posted July 17, 2017 Posted July 17, 2017 You could try MKV Optimizer: https://www.htpc-tools.de/mkv-optimizer/ (German) The application has English and German language support! Pretty much what the OP asked for I think...works pretty slick too. Thanks for the info!
