Jdiesel 1435 Posted May 2, 2017 Posted May 2, 2017 On the live TV guide the program label starts at the beginning of the guide cell. This is fine for shows that have just started or shows airing in the future however it clips off the label on show that have already started. The default view when loading the guide is to have the current time on the left edge of the screen meaning you have to arrow over to the left to see the labels on some in progress shows (sometime quite far if the show started a few hours prior). An example, the movie Batman Begins started at 8:00 am on channel 25 but the label is already cut off so there is no way of know what is airing on channel 25 unless you arrow to the left an hour or click on the blank cell. Would if be possible to center the label relative to the visible portion of the cell? 2
arrbee99 1836 Posted May 2, 2017 Posted May 2, 2017 Or something like iPlayer guide - if you change the time position you can watch the individual program 'data' slide over as required.
denz 501 Posted May 2, 2017 Posted May 2, 2017 (edited) It should be how it is in wmc and how it is now in the roku app. Edited May 3, 2017 by denz
Luke 42243 Posted May 7, 2017 Posted May 7, 2017 The labels are being updated so that they always stick to the line, which will allow them to remain visible even as you scroll to the right. Thanks for the feedback. @, I can't find your other topic about this.
Guest asrequested Posted May 7, 2017 Posted May 7, 2017 The labels are being updated so that they always stick to the line, which will allow them to remain visible even as you scroll to the right. Thanks for the feedback. @, I can't find your other topic about this. @@Luke you mean this one? https://emby.media/community/index.php?/topic/46278-guide-activity-is-odd/
