robck 1 Posted May 1, 2017 Posted May 1, 2017 My first post, so please bear with me. I'm trying to figure why this file is transcoding. I've tried streaming it on Serviio and it direct plays, but with Emby, it tries to transcode it to h264. Under the custom profile, I've added mkv: video codec: h264,hevc,h265 audo codec: aac,ac3,mp3,dca,dts i've also removed any restrictions under the "Codec" tab of the profile I set the max streaming Video bitrate as: 60000000 I've set the max audio transcoding bitrate as: 5999996 Media Info VideoCodecHEVCProfileMain 10Level150Resolution3840x1608Aspect ratio2.40:1AnamorphicNoInterlacedNoFramerate23.97602Bitrate26659 kbpsPixel formatyuv420p10leRef frames1TitleEng Arrival (2016) - Release for ULTRAHDCLUB AudioLanguageengCodecDTSProfileDTS-HD MALayout7.1Channels8 chSample rate48000 HzBit depth24 bitDefaultNoTitleEng DTS-HD MA 7.1 @ 4207 kbps AudioLanguagefreCodecAC3Layout5.1Channels6 chBitrate640 kbpsSample rate48000 HzDefaultNoTitleFre Dolby Digital 5.1 AudioLanguagespaCodecAC3Layout5.1Channels6 chBitrate640 kbpsSample rate48000 HzDefaultNoTitleSpa Dolby Digital 5.1 SubtitleLanguageengCodecPGSSUBDefaultYesForcedNoExternalNoTitleEng Default SubtitleLanguageengCodecPGSSUBDefaultNoForcedNoExternalNoTitleEng SubtitleLanguagefreCodecPGSSUBDefaultNoForcedNoExternalNoTitleFre SubtitleLanguageengCodecPGSSUBDefaultNoForcedNoExternalNoTitleEng SubtitleLanguageengCodecPGSSUBDefaultNoForcedNoExternalNoTitleEng SubtitleLanguagefreCodecPGSSUBDefaultNoForcedNoExternalNoTitleFre SubtitleLanguagespaCodecPGSSUBDefaultNoForcedNoExternalNoTitleSpa SubtitleCodecSRTDefaultNoForcedNoExternalYesTitleUnd Containermkv The file below with media info direct plays fine: Media Info VideoCodecHEVCProfileMain 10Level150Resolution3840x1606Aspect ratio2.40:1AnamorphicNoInterlacedNoFramerate23.97602Bitrate30366 kbpsPixel formatyuv420p10leRef frames1TitlePassengers (2016) - Release for ULTRAHDCLUB AudioLanguageengCodecDTSProfileDTS-HD MALayout5.1Channels6 chSample rate48000 HzBit depth16 bitDefaultYesTitleEng DTS-HD MA 5.1 @ 2119 kbps - Blu-ray EUR AudioLanguagefreCodecDTSProfileDTSLayout5.1Channels6 chBitrate1536 kbpsSample rate48000 HzDefaultNoTitleFre DTS 5.1 AudioLanguagespaCodecAC3Layout5.1Channels6 chBitrate640 kbpsSample rate48000 HzDefaultNoTitleSpa Dolby Digital 5.1 AudioLanguagerusCodecAC3Layout5.1Channels6 chBitrate640 kbpsSample rate48000 HzDefaultNoTitleRus AC3 5.1 @ 640 kbps - DUB, Blu-ray EUR AudioLanguageukrCodecAC3Layout5.1Channels6 chBitrate640 kbpsSample rate48000 HzDefaultNoTitleUkr AC3 5.1 @ 640 kbps - DUB, Blu-ray EUR SubtitleLanguagerusCodecSUBRIPDefaultNoForcedNoExternalNoTitleRus Forced, iTunes SubtitleLanguagerusCodecSUBRIPDefaultNoForcedNoExternalNoTitleRus iTunes SubtitleLanguageukrCodecSUBRIPDefaultNoForcedNoExternalNoTitleUkr Forced, iTunes SubtitleLanguageukrCodecSUBRIPDefaultNoForcedNoExternalNoTitleUkr iTunes SubtitleLanguageengCodecSUBRIPDefaultNoForcedNoExternalNoTitleEng iTunes SubtitleLanguageengCodecPGSSUBDefaultNoForcedNoExternalNoTitleEng SubtitleLanguageengCodecPGSSUBDefaultNoForcedNoExternalNoTitleEng SubtitleLanguagefreCodecPGSSUBDefaultNoForcedNoExternalNoTitleFre SubtitleLanguagefreCodecPGSSUBDefaultNoForcedNoExternalNoTitleFre SubtitleLanguagespaCodecPGSSUBDefaultNoForcedNoExternalNoTitleSpa Containermkv Path
Luke 42239 Posted May 1, 2017 Posted May 1, 2017 Hi there, can you please attach the emby server and transcoding log? you can learn how to do that here: https://emby.media/community/index.php?/topic/739-how-to-report-a-problem/ thanks !
robck 1 Posted May 2, 2017 Author Posted May 2, 2017 Well I sort of fixed it. By using what someone else did. Simply use the vlc or kodi profile style. Direct play all files. And so files that it can't decode. Simply say can't playback file. Which i think is very few anyways.
Luke 42239 Posted May 2, 2017 Posted May 2, 2017 Yea that will work. I think we're going to start doing that for the default profile anyway. Thanks.
