crashbowman 1 Posted April 30, 2017 Posted April 30, 2017 Hey guys, I am at a bit of a loss and don't even know where to start. Really don't know where my issues resides, but recently my Schedules Direct membership expired so Emby stopped recording, etc. I renewed with SD, but now nothing will work. I'm not getting guide data, channels don't show, etc. I have tried everything including deleting my guide provider and re-adding it. I can add in my SD account info and choose a guide, but nothing will show up and if I go to the "map channels" button there are no channels listed. Any help would be great. Thank you!
Luke 42243 Posted April 30, 2017 Posted April 30, 2017 Hi, can you please refresh the guide, then attach the emby server log? you can learn how to do that here: https://emby.media/community/index.php?/topic/739-how-to-report-a-problem/ thanks !
Luke 42243 Posted April 30, 2017 Posted April 30, 2017 Well there's nothing obvious here. If you put this url into a browser, what is the result? http://192.168.1.136:80/lineup.json 1
Luke 42243 Posted April 30, 2017 Posted April 30, 2017 Well that's the channel list from your tuner so this is not a schedules direct problem. It looks like your tuner is reporting 0 channels. I suspect you need to go into the HDHR software and run a channel scan.
CBers 7554 Posted May 1, 2017 Posted May 1, 2017 Make sure you have the latest firmware on your HDHomeRun. https://forum.silicondust.com/forum/viewtopic.php?f=119&t=20613
