3rob3 1 Posted April 29, 2017 Posted April 29, 2017 I can watch live TV and all videos in perfect sync, but when I watch a recording the audio is way out of sync with the video (unwatchable). This happens on both my Shield TV and Nexus Player. One possible clue is if I change settings to downmix to stereo the audio is back in sync (but obviously not an ideal solution). Any ideas?
ebr 16337 Posted April 30, 2017 Posted April 30, 2017 Changing the audio setting is probably causing a transcode while the others are direct playing. Did you have one of the conversion options on when it was recorded?
3rob3 1 Posted April 30, 2017 Author Posted April 30, 2017 Thanks for the reply. No, I have the conversion settings turned off. They are .TS files. If I play them on the Emby server they also play fine.
ebr 16337 Posted May 1, 2017 Posted May 1, 2017 Okay, then you could try turning on the conversion but, to investigate more we will need the information and logs described in How to Report a Problem Thanks.
nominion 7 Posted May 1, 2017 Posted May 1, 2017 (edited) I have noticed similar out of sync audio on recorded TV shows when played on my NVIDIA Shields. Emby is setup to convert my recordings to MP4 with "Preserve original audio when converting recordings (when possible)" checked. Movies in MP4 format seem to be fine and show no out of sync audio issues. Edited May 1, 2017 by nominion
Luke 42245 Posted May 2, 2017 Posted May 2, 2017 @@nominion, as a test, what if you convert to mkv. Does that exhibit the same problem? thanks !
3rob3 1 Posted May 2, 2017 Author Posted May 2, 2017 @@3rob3, how are they being recorded? Hi. They are being recorded using Schedules Direct, via HDhomerun Prime, and are being saved as .TS files (no conversion option enabled). I also have a ServerWMC setup running if you want me to switch to that. I was playing around last night attempting to get the log files for you guys, but I only had one recording. It played back perfectly (it was stereo only so I think that is another clue), so I need to record something else to get the logs. Will try tonight. Thanks for the help.
Luke 42245 Posted May 2, 2017 Posted May 2, 2017 What if you try using the conversion feature, like for example converting to mkv? Let us know if that makes any difference. thanks !
3rob3 1 Posted May 2, 2017 Author Posted May 2, 2017 Okay, then you could try turning on the conversion but, to investigate more we will need the information and logs described in How to Report a Problem Thanks. EBR, I sent the log from my Shield TV. User was 'Rob', and I was playing a recording of 'Fixer Upper' at 5:46pm EST. Also, attached is my server log from the same time. Thanks for the help with this! Log.txt
nominion 7 Posted May 2, 2017 Posted May 2, 2017 I have changed the settings on my server to convert recordings to MKV. I believe there are a few things queued up to record tonight, so I should be able to test tomorrow. I'm not sure if this is related, but recent recordings are taking 30 to 45 seconds to start once I hit play. I get the spinning wheel. It's almost as though the server is trying to figure out the bit rate and format (trying to determine if it needs to be transcoded maybe?). This started around the same time as the out of sync audio for Recorded TV. What is even more interesting, if I watch a recording from months ago, it starts almost instantly.
3rob3 1 Posted May 2, 2017 Author Posted May 2, 2017 What if you try using the conversion feature, like for example converting to mkv? Let us know if that makes any difference. thanks !Hi. Converting to MKV also works fine (in sync). I even tried keep original audio and it was fine as well. Only the raw recordings (.TS files) seem to have an issue.
3rob3 1 Posted June 18, 2017 Author Posted June 18, 2017 Just circling back to see if there's any update on this?
Luke 42245 Posted June 21, 2017 Posted June 21, 2017 @@3rob3 have you tried new recordings with the latest release of emby server? Thanks !
3rob3 1 Posted June 26, 2017 Author Posted June 26, 2017 Hi, I just posted in another thread (Shield TV muting). I haven't been able to test because everything gets muted now as soon as I start playing TV. Very strange.
Luke 42245 Posted June 27, 2017 Posted June 27, 2017 @@3rob3 what exactly do you mean by muted? are you able to unmute with your remote and/or turn up the volume?
ebr 16337 Posted June 27, 2017 Posted June 27, 2017 @@3rob3 what exactly do you mean by muted? are you able to unmute with your remote and/or turn up the volume? Its an odd bug on the Shield when the CEC volume control option is turned on. Any manipulation of volume will unmute the stream.
Luke 42245 Posted June 27, 2017 Posted June 27, 2017 Ok just wanted to make sure we weren't delivering incompatible audio. thanks.
BAlGaInTl 288 Posted June 29, 2017 Posted June 29, 2017 (edited) I can watch live TV and all videos in perfect sync, but when I watch a recording the audio is way out of sync with the video (unwatchable). This happens on both my Shield TV and Nexus Player. One possible clue is if I change settings to downmix to stereo the audio is back in sync (but obviously not an ideal solution). Any ideas? Out of curiosity... is this OTA TV? I experienced this same issue with the TS container on my OTA setup. When pixilation/noise occurs from weather or weak signal, the audio on recordings would get further and further out of sync. I now have it convert to MKV preserving the audio, and it works MUCH better. Emby's handling of the noise seems greatly improved over the past couple months. Edited June 29, 2017 by BAlGaInTl
Luke 42245 Posted July 1, 2017 Posted July 1, 2017 Out of curiosity... is this OTA TV? I experienced this same issue with the TS container on my OTA setup. When pixilation/noise occurs from weather or weak signal, the audio on recordings would get further and further out of sync. I now have it convert to MKV preserving the audio, and it works MUCH better. Emby's handling of the noise seems greatly improved over the past couple months. Thanks for the feedback.
ebr 16337 Posted July 3, 2017 Posted July 3, 2017 It might be worth re-trying this with the latest beta of the Android TV app (1.4.21+) as the internal player has been updated. Thanks.
