FordGT90Concept 103 Posted April 29, 2017 Posted April 29, 2017 (edited) There are two programs recording. It is not possible to tune to any thing else. I tried through web app and the NVIDIA SHIELD TV Android TV app (logs submitted). 192.168.0.159 (HDHomeRun EXTEND) Tuner 0 Channel: 189.000 MHz Tuner 1 Channel: 683.000 MHz 192.168.0.160 (HDHomeRun EXTEND) Tuner 0 Channel: none Tuner 1 Channel: none 192.168.0.161 (HDHomeRun EXTEND) Tuner 0 Channel: none Tuner 1 Channel: none Edit: I have verified 160 and 161 are responding to web requests to watch TV (watched a bit via MPC-HC). logs.zip Edited April 29, 2017 by FordGT90Concept
FordGT90Concept 103 Posted April 29, 2017 Author Posted April 29, 2017 (edited) I'm almost positive this issue is related to the issue in this thread: https://emby.media/community/index.php?/topic/46663-live-tv-broke-less-than-24-hours-after-update/ The two recordings finished. All 6 tuners are now available. I tried to tune to a channel on the NVIDIA SHIELD and it is giving the exact same error it did before (no available tuners). Live TV doesn't work at all on the web either. Attempting to use three tuners at once appears to completely break Emby Live TV. The logs attached here are the same as above but include trying Live TV after the recordings finished. I'm now obligated to restart Emby Server to make Live TV work again. logs.zip Edited April 29, 2017 by FordGT90Concept
FordGT90Concept 103 Posted April 29, 2017 Author Posted April 29, 2017 I tried to reproduce this and the bug failed to present itself. Two shows were recording, three were watching via web, and one was on Android TV. Minimal problems observed. Something happened between the restart in the wee hours of the morning and ~9 am when I tested. Between server restart and ~10 am, the problem had not recurred.
Luke 42200 Posted May 2, 2017 Posted May 2, 2017 hi @@FordGT90Concept, Since the issue failed to present itself, is there still an issue? Thanks !
FordGT90Concept 103 Posted May 2, 2017 Author Posted May 2, 2017 (edited) It successfully recorded three things simultaneously last night so I'm thinking not but tonight is the real test... I'm thinking one of the beta updates fixed it. Edited May 2, 2017 by FordGT90Concept
legallink 187 Posted May 2, 2017 Posted May 2, 2017 @@FordGT90Concept, I've had this issue previously as well and 2 things worked for me. 1. A restart (like you did). 1.5 (maybe) delete and reset series recordings. 2. Patience. I am/was converting the files to MP4, and the MP4 didn't show up in the episode folder til a little bit after the show was completed.....and I was watching for it immediately. Note that #2 would not have solved what #1 did. I had an instance or 2 where, when multiple shows were supposed to record, I only got the first few minutes of them.....and that was checking the next morning. I was going to post a bug, but restarted, did a test, and it worked. In my experience, I had to delete and redo the series recordings. I'm not sure why, but I haven't had any issues since. That being said, I did this, I want to say one or 2 months ago? It's been fine since.
FordGT90Concept 103 Posted May 3, 2017 Author Posted May 3, 2017 There was an issue last night but I don't think it is related to >2 tuners. I believe the issue is fixed in the latest beta.
