bloemb 2 Posted April 28, 2017 Posted April 28, 2017 Hi there! first of all I would like to thank you guys for making such an great App! I have just discovered Emby and after a couple of testing weeks I might go Emby Premiere if everything works to my satisfaction! ;-) I'm running Emby Version 3.2.13.0 on a QNAP Nas with QTS4.3.3 Now if I use Microsoft Edge 40.15063.0.0 and go to "Movies" and select "Genres", I just get a list of all different genres but no movies are displayed. If I do the same with IE11 it works fine. let me know if you need any further information and I found a little typo in the german admin interface. If you go on "Einstellungen" - "Markierungen" there is following text: "Personalisieren Sie das Erscheinen von Empy um es Ihren eigenen Bedürfnissen, oder die Ihrer Organisation, anzupassen." maybe use "Aussehen" instead of "Erscheinen" makes more sence too. hope that helps cheers Päde
Luke 42200 Posted April 29, 2017 Posted April 29, 2017 hi @@bloemb, thanks for the report. we'll take a look at these.
