drewtlo 0 Posted April 26, 2017 Posted April 26, 2017 (edited) Hello, I've been trying to configure pulling xmltv data using ZAP2IT. I am getting channel data, but nothing in the guide. I am running the perl script using perl zap2xml.pl -u drewtlo@emaildomain.com -p password The XMLTV file is being generated, and the channel mapping looks okay, so I'm not sure why my guide is empty. I've attached my server log and xmltv file as well. Any help would be greatly appreciated. Thank you Log.txt xmltv.xml Edited April 26, 2017 by drewtlo
Luke 42238 Posted April 26, 2017 Posted April 26, 2017 Hi, it looks like you have schedules direct setup so it might be trying to use that. can you please remove schedules direct, then refresh the guide and see if the issue persists? If the issue persists please attach a new server log. thanks !
drewtlo 0 Posted April 27, 2017 Author Posted April 27, 2017 Thanks Luke. I rolled back to Schedules Direct when I couldn't get XMLTV to work. I'll put XMLTV back tomorrow and generate a new log. Have a good evening
Luke 42238 Posted May 5, 2017 Posted May 5, 2017 The latest version of Emby Server for Mac has been posted. Apologies for the delay. Thanks !
