robnix 3 Posted February 12, 2014 Posted February 12, 2014 Are auto boxsets working in MBT? I have them setup and I can see the sets that have been created in the directory I created, but I don't see them in MBT anywhere.
Koleckai Silvestri 1154 Posted February 12, 2014 Posted February 12, 2014 Nothing shows under Movies -> Collections? What version of the server are you using?
Solution robnix 3 Posted February 13, 2014 Author Solution Posted February 13, 2014 User Error - I didn't figure out that I needed to add the path to my media collections Working great now, love the plugin! 1
foghat 65 Posted February 22, 2014 Posted February 22, 2014 2 questions: 1. I can see the box sets under Movies --> Box Sets or under Collections --> Movies. Is there any way to display the box sets (instead of the individual movies) under Movies --> All Movies? 2. Under Collections --> Movies for each movie that is part of a box set I see a two entries. One that was created by auto box set plugin. And another based on what I had set up manually (root Alien folder with sub folders for each movie). Anyone know if there is a way to not show my manually created one - aside from pulling the movies out of the root folder? Thanks.
ebr 16343 Posted February 22, 2014 Posted February 22, 2014 If you use the auto plug-in, you'll want to remove the manual ones.
foghat 65 Posted February 22, 2014 Posted February 22, 2014 If you use the auto plug-in, you'll want to remove the manual ones. Thanks. What about question 1? Any way to view box sets in Movies --> All Movies? And is the only way to remove the manual ones by pulling the movies out of the root folder and then deleting the root folder?
ebr 16343 Posted February 22, 2014 Posted February 22, 2014 I guess you are talking about in the web client for All Movies? This will depend on the logic employed by each client for those views but I would thing you wouldn't see box sets in an All Movies view since they are not movies, but collections of movies.
