FlyGuy94 6 Posted April 25, 2017 Posted April 25, 2017 Hi I'm having trouble with one part of the server. When I click on the TV tab nothing is loaded but it shows on the startpage and it is playable and I am able to browse. But when I return to the TV folder everything is gone. This is the pastebin log https://pastebin.com/93tc9B9t I also attached some screens of the problem. Thanks in advance
Luke 42245 Posted April 25, 2017 Posted April 25, 2017 Maybe those are coming from your Recordings folder?
FlyGuy94 6 Posted April 25, 2017 Author Posted April 25, 2017 Yes indeed your right but I if I remove it it comes back automatically with the next media scan I don't understand why it does that.
Luke 42245 Posted April 26, 2017 Posted April 26, 2017 Because the path you configure in Live TV for recordings becomes a regular Emby library. It's not optional. For the TV library, what paths have you added to it? 1
FlyGuy94 6 Posted April 26, 2017 Author Posted April 26, 2017 Nevermind fixed it by not using live tv I wasn't using it anyway it was just for testing.
