Allow custom filename regular expressions
Hi,
It would be nice to have customization options for filenames.
I have filenames in format of:
/Series/Series Name/Season X/N - Episode Name.mkv
X=season number
N=episode number
Those work ok, except in multi-episodes which are in format of:
01-02 - Episode Name.mkv
I work a lot in console (and I hate duplicate information) so long filenames are not a good idea.
If you could make config option for regular expressions for filenames, f.e. like in kodi:
<tvshowmatching action="prepend">
<regexp>Season[\._ ]([0-9]+)[\\/]([0-9]+)([^\\/]*)$</regexp>
</tvshowmatching>
If that's not possible, could you point out where in the code I can most easily make it work and I can just start compiling my own :)?
It's a possibility for the future. Thanks.
  • Like 1
  • 2 weeks later...
This and DVD order are only thing holding me from ordering lifetime subscription, so hopefully soon.
  • 6 months later...
Bought lifetime subscription, hopefully you have time for either of these soon!
Thanks for your support !
  • 3 years later...
