Video will freeze for a few seconds and the resumes
I have a problem with some of my movies freezing about every 15 minutes for a few seconds and increasing in length of freeze each time. I have tried the opening the file with different video players but it does the same thing. Any ideas?
MKV file running in MBT, MBC, VLC...not all files to do it just a certain few and I cant see why it would
does it happen outside mb as well?
Yes
Ok the files sound a little hosed.
When it freezes does the sound continue?
Did you rip them yourself?
It may just be a simple fix (remux using mkvmerge) or they may need to be reencoded.
Yes the sound continues and the video will speed up to catch up to the sound, not I didn't rip them
Ok try a simple remux with mkvmerge it sounds like the data is there but the  time stamps may be a bit wonky.
Edited by Tikuf
Ok, I have found that its not the files...for some reason its doing it with all of the files on one particular HD. Its strange as its a new HD and the same as what I have has my secondary HD
I used to have this happen a lot, and occasionally it still does. It's caused by the HD. Check you settings and see if there are any power saving things that turn of hard drives or something. If you listen carefully, you can hear the HD noise as it does it.
It doesn't mean there's a problem with the drive though,  but try a defrag and cleanup too.
are your movies on the same physical drive as the system drive or the virtual memory disc for your server system. I was having a similar problem, and never noticed that the affected movies were on the same drive as that of the system OS. Once I moved them I no longer have this issue
Edited by LASooner
get crystal disk info, http://crystalmark.info/software/CrystalDiskInfo/index-e.html
run the program, it will list each of your drives and say good, caution, or bad. depending on the smart status health of the drive.
(it will tell you if your drive is dying)
RE: above "virtual memory" post
if your system has more than 2 gb of actual memory, you can disable windows virtual memory system all together, or limit it to 512mb without any repercussions. old technology for old hardware. if you have less than 2gb ram, i'm not surprised at your issues.
Edited by trusselo
the disk is fine and I have 4 gigs of ram, it is apparently a known issue for that model
