bardmaster 17 Posted April 22, 2017 Posted April 22, 2017 So I'm running Emby Server as a service on a WSE2012R2 server with a Core i7-3770, but the motherboard does not include GPU integration so I cannot access the CPU's HD4000 (which is pretty crappy anyway). I stuck an ancient graphics card in it solely to manage the server locally as needed. I ran GPU-Z and the only option I have is software acceleration. I assume that means I don't have the option to use Emby's hardware acceleration in any form, am I correct? I am very interested in using Emby to stream LiveTV from my HDHomeRun Prime to various devices, particularly Roku boxes. Would it be beneficial to install a decent graphics card in the server solely for hardware acceleration? Appreciate any thoughts out there!
Solution Luke 42200 Posted April 23, 2017 Solution Posted April 23, 2017 Well you have an i7 which is already a very capable CPU. Once we improve the load balancing between gpu and cpu then I would imagine it might increase simultaneous transcodes but generally speaking I think your cpu is enough. 1
