Bug in LiveTV guide on Android
zigzagtshirt
I have attached two screenshots of the Live TV guide.  One screen shot is from the web app, the other is from Android app.
You will see on the web app screenshot that the guide data is visible for channels 590 and 592.
However, when you look at the guide in the Android app, the guide data is not visible for these two channels.  The guide data is in fact there, but you have to scroll to the left (backwards in time) all the way until the time that particular program started.  In this example, you have to scroll through several hours worth of guide data to see it.  The guide data in Android doesn't get "pushed" to the current time block like what happens in the web app.
thanks for the report. we'll take a look.
