screwfaze 38 Posted April 15, 2017 Posted April 15, 2017 Hi, I hope someone can help i keep having issues with playback on Android Tv box over the internet where it freezes for a while then continues or sometimes restarts. I have sent logs at approx 19:25 user is Aminah would appreciate any help. Thanks
ebr 16337 Posted April 16, 2017 Posted April 16, 2017 The only thing I see in your log is some periodic slow network response which would explain what you are describing. What are the details of the connection on both ends? At what bitrate are you attempting to stream?
screwfaze 38 Posted April 16, 2017 Author Posted April 16, 2017 Hi ebr, I have good internet on both sides 10Mbps up on the Server side and 100Mbps down on the Android TV side. I have tried various bitrate settings on the Client from Auto, 5-1 Mbps but problems seems to persist. I have also tried restarting the Routers when this happens but has not made much difference. If all you are seeing on the logs is network slowdowns then I guess problem is not with Emby I just wanted to confirm this. Thanks
Luke 42244 Posted April 17, 2017 Posted April 17, 2017 If you can attach your Emby Server and ffmpeg logs as well, then we can look for any possible issues there too. You can learn how to do that here: https://emby.media/community/index.php?/topic/739-how-to-report-a-problem/ Thanks !
