Vassley 1 Posted April 15, 2017 Posted April 15, 2017 Hi guys is there any plans to support fire fox os on Panasonic tv's 1
Luke 42248 Posted April 15, 2017 Posted April 15, 2017 We hope to support that in the future. Thanks ! 1
Gu1b0 0 Posted August 15, 2017 Posted August 15, 2017 (edited) Hi, i'm a (ex)Plex user. I'm looking to switch to Emby, there is a plan for FirefoxOs? Maybe with Premiere Support? thank you Edited August 15, 2017 by Gu1b0
Luke 42248 Posted August 15, 2017 Posted August 15, 2017 Hi, i'm a (ex)Plex user. I'm looking to switch to Emby, there is a plan for FirefoxOs? Maybe with Premiere Support? thank you Hi @@Gu1b0, our http://tv.emby.media app should already work great on Firefox OS.
Gu1b0 0 Posted August 15, 2017 Posted August 15, 2017 (edited) i'm trying with Browser, but the interface resolution (browser) is not perfect. There is also the url bar on the top... And it's a bit slow However, if i go on DLNA menu from my Pana, i can start streaming via pc. Very fast with evansport support. I'm using the top-right icon in emby. It works very well, but i'm asking if there will be an app for my Pana ez950 via firefox os store Edited August 15, 2017 by Gu1b0
Luke 42248 Posted August 15, 2017 Posted August 15, 2017 It must have a fullscreen option, no? We'd like to get the same app into the firefox os store, yes.
Luke 42248 Posted August 15, 2017 Posted August 15, 2017 Yes there is. Use the Panasonic html5 iptv app launcher to launch http://tv.emby.media
Gu1b0 0 Posted August 15, 2017 Posted August 15, 2017 Yes there is. Use the Panasonic html5 iptv app launcher to launch http://tv.emby.media I'll try, thank you
Gu1b0 0 Posted August 16, 2017 Posted August 16, 2017 (edited) Thanks for the feedback. i've tried but there is an error when generating the pin, and when adding the server manually i cannot enter numbers. The TV does not see that graphical interface for a text imput... so keyboard does not "pop out". Edited August 16, 2017 by Gu1b0
Luke 42248 Posted August 16, 2017 Posted August 16, 2017 Sounds like something is blocking your connection to our Emby Connect server, https://connect.emby.media
mrjay000 0 Posted October 2, 2017 Posted October 2, 2017 i've tried but there is an error when generating the pin, and when adding the server manually i cannot enter numbers. The TV does not see that graphical interface for a text imput... so keyboard does not "pop out". i got the same error. i'm using emby on xpenology. emby ports are forwarded so not sure what's the issue.
Luke 42248 Posted October 2, 2017 Posted October 2, 2017 i got the same error. i'm using emby on xpenology. emby ports are forwarded so not sure what's the issue. What device and Emby app are you trying to use? thanks.
mrjay000 0 Posted October 2, 2017 Posted October 2, 2017 (edited) I’m trying to use the Panasonic html5 iptv app launcher to launch http://tv.emby.media. Edited October 2, 2017 by mrjay000
Luke 42248 Posted October 2, 2017 Posted October 2, 2017 And what error are you getting and on what screen?
mrjay000 0 Posted October 2, 2017 Posted October 2, 2017 And what error are you getting and on what screen?It say that it can’t generate the pin and to try again.I tried to add the ip manually but it doesn’t work. Tried with the panasonic remote app and didn’t work also Sent from my iPhone using Tapatalk
Luke 42248 Posted October 2, 2017 Posted October 2, 2017 Ok, it sounds like something is blocking internet access from inside the app.
mrjay000 0 Posted October 2, 2017 Posted October 2, 2017 Ok, it sounds like something is blocking internet access from inside the app.I don’t have any problems with other links.I put google.com and it’s working Sent from my iPhone using Tapatalk
ebr 16339 Posted October 2, 2017 Posted October 2, 2017 Google is a well-known and trusted site. Is it possible something is blocking unknown sites?
mrjay000 0 Posted October 3, 2017 Posted October 3, 2017 i managed to make plex work, using plex.tv/web, also using other websites, so i'm not sure it's something in the tv app.
sleepy 10 Posted March 10, 2018 Posted March 10, 2018 Old thread I know but I've just got a Panasonic TV and I can't get the Emby Web Client to work. I put http://tv.emby.media/ into the TV Web Browsr which loads up the web client fie. However, when I click on anything, nothing happens. I can't progress any further than the Emby home screen. If I want to click on TV Shows for instance, I can move the mouse over that icon and it highlights it with a green border but it doesn't open. I hope you can assist please.
Luke 42248 Posted March 11, 2018 Posted March 11, 2018 Have you tried clicking on ok the remote while the mouse is also over it at the same time?
sleepy 10 Posted March 11, 2018 Posted March 11, 2018 Hi Luke, yes I've tried that. I also plugged in a USB Keyboard to see if that works but it is exactly the same, I can't select anything on the Home screen.Very strange behaviour!
