etrax 0 Posted April 11, 2017 Posted April 11, 2017 HiThere is now a problem with certain HD channels on the Chromecast it shows top half of the picture and sutters, the "SD" channels work fine. This has worked before im not sure when this changed since i havent had a active iptv subscription for some months.
Luke 42243 Posted April 11, 2017 Posted April 11, 2017 Hi there @@etrax, we're very sorry to hear about this. In order for us to best help you, please discuss a specific example, and then please accompany that example with the information requested in how to report a media playback issue. Thanks !
Luke 42243 Posted April 11, 2017 Posted April 11, 2017 Ok, I'm not quite sure what the issue is, but I notice we're stream copying the original video stream. If you go into app settings and set the max chromecast bitrate to something like 4mbps, that should force it to do a full transcode. Let me know if the full transcode performs better. Thanks.
etrax 0 Posted April 12, 2017 Author Posted April 12, 2017 (edited) Ok, I'm not quite sure what the issue is, but I notice we're stream copying the original video stream. If you go into app settings and set the max chromecast bitrate to something like 4mbps, that should force it to do a full transcode. Let me know if the full transcode performs better. Thanks. Yes that works better with both 1080p 4mbps and 720p 4mbps, thanks! Also as a side note when i sent you the logs yesterday i shut chromecast down and i noticed 5 minutes later that ffmpeg.exe was still using alot of cpu. Edited April 12, 2017 by etrax
Blob 7 Posted April 12, 2017 Posted April 12, 2017 (edited) Yes that works better with both 1080p 4mbps and 720p 4mbps, thanks! Also as a side note when i sent you the logs yesterday i shut chromecast down and i noticed 5 minutes later that ffmpeg.exe was still using alot of cpu. Hi, +1 I can confirm the behavior. Certain live hdhomerun channels only on Chromecast, and when transcoding problem is not there. Have not checked if ffmpeg was running after the shutdown though... Edited April 12, 2017 by Blob
