ebr 16337 Posted July 14, 2017 Posted July 14, 2017 Medieninformation Video CodecH264AVCYes ProfilHigh Level40 Auflösung1920x1080 Seitenverhältnis16:9 AnamorphNo InterlacedNo Framerate23.9760246 Bitrate3194 kbps Bit-Tiefe8 bit Pixelformatyuv420p Ref Frames4 NAL4 Audio CodecAACProfilLC Darstellungstereo Kanäle2 ch Sample-Rate44100 Hz VoreinstellungYes TitleAAC stereo Default Untertitel SprachegerCodecSSA VoreinstellungYes ErzwungenNo ExternNo TitleGer Default Untertitel SpracheengCodecSSA VoreinstellungNo ErzwungenNo ExternNo TitleEng Containermkv But I didn't used VLC Player to play the file, I used the Internal player of the emby app. Thanks. The app was attempting to play it in an embedded version of VLC and does not like it. If you have the actual VLC app installed on the box, I'd be interested in whether or not it can play the file directly.
ebrithiljonas 5 Posted July 14, 2017 Author Posted July 14, 2017 If I set emby to use an external player and then select VLC, it plays everything perfectly, no errrors and the subtitles get rendered correctly
ebr 16337 Posted July 14, 2017 Posted July 14, 2017 If I set emby to use an external player and then select VLC, it plays everything perfectly, no errrors and the subtitles get rendered correctly Okay. Until we can figure out exactly what is going wrong here, that may be your best option.
ebrithiljonas 5 Posted July 14, 2017 Author Posted July 14, 2017 Yeah thats what I have been doing the whole time, I hope that you can fix it, just tell me if you need anything from me, like example files or so.
ebr 16337 Posted July 14, 2017 Posted July 14, 2017 If you can provide me a dropbox or similar link to a sample file, that would be great. Thanks.
ebrithiljonas 5 Posted July 14, 2017 Author Posted July 14, 2017 Ok, I sended you the downloadlink to the samplefile per pm because I don't own that file so I don't want to distribute it on the internet 1
ebrithiljonas 5 Posted July 19, 2017 Author Posted July 19, 2017 ebr you are a wizard! I tested it with version: 1.3.25g and everything worked perfectly, no skipping and the subtitles are rendered correctly, thank you so much.
