Dibbes 515 Posted April 10, 2017 Posted April 10, 2017 CoverArt does not seem to recognize Half-OU as 3D and doesn't put the 3D overlay. Half-SBS works fine and overlay works.
loomes 40 Posted April 10, 2017 Posted April 10, 2017 Here is working fine with SBS an HOU. CoverArt 4.0.26.0.
Dibbes 515 Posted April 10, 2017 Author Posted April 10, 2017 (edited) Here is working fine with SBS an HOU. CoverArt 4.0.26.0. I have quite a bunch of HOU, and none of them get the overlay. I'm on the same version as you are. Maybe I made a config mistake, I'll check. EDIT: I don't see where I could have made a mistake, when SBS works... Edited April 10, 2017 by Dibbes
Solution ebr 16342 Posted April 11, 2017 Solution Posted April 11, 2017 CoverArt doesn't really recognize it at all. That is a function of the server and CoverArt just allows you to indicate it on the cover. So, you need to be sure you are properly designating the item as 3D using the proper conventions for the server. 3D videos 1
Dibbes 515 Posted April 11, 2017 Author Posted April 11, 2017 CoverArt doesn't really recognize it at all. That is a function of the server and CoverArt just allows you to indicate it on the cover. So, you need to be sure you are properly designating the item as 3D using the proper conventions for the server. That explains it, I suppose. The filename (and more files like these) "Star.Trek.Beyond.2016.1080p.3D.BluRay.Half-OU.x264.TrueHD.7.1.Atmos.mkv" is not automatically detected as 3D. Thanks for helping out! It's appreciated
Happy2Play 9814 Posted April 11, 2017 Posted April 11, 2017 You can manually make them 3D in Edit Info. There is a "3D format:" field with a drop-down box if you don't want to rely on naming convention. 1
Dibbes 515 Posted April 11, 2017 Author Posted April 11, 2017 Yes, a library scan needs to be run after, though. If that's not done, CoverArt will still not put the overlays.
