Rona 0 Posted April 8, 2017 Posted April 8, 2017 I have Emby Server 3.2.10.0-1 installed on my Synology DS215+ NAS (DSM 6) I have a Elgato DVB-T USB TV tuner and have installed NextPVR on Windows 8.1 64-bit On the Synology DS215+ NAS I have added the NextPVR plugin to Emby Server. Then I use a LG Adagio PF1000UT projector to watch the Emby/NextPVR TV streams. This works fine, expect for when switching channels after I stop a stream of for example TV channel nr.4 then I need to wait 5 to 10 seconds before I can switch to another TV channel nr.6. Because If I don't wait, the stream of TV channel nr.4 just starts again from the beginning that I started watching it. (I think it has to do that the temporary recorded file needs to get deleted before another TV stream of another TV channel can be started) Worse is that almost every day at some moment the TV gets previous behaviour and waiting 5 to 10 seconds doesn't help anymore and the temporary recorded file doesn't get deleted anymore. No matter what channel I try to switch to, it just starts over the last played stream. Only a restart of the Emby Server can fix the problem until it happens again the next day. Sometimes it also happened while watching a TV stream and suddenly the TV stream restarted from the beginning. After that also the only way to fix the problem was tot restart Emby Server on the Synology. This behaviour also happened when using the ServerWMC plugin in Emby Server on the Synology. Anything that can be done to prevent this from happening?
Rona 0 Posted April 9, 2017 Author Posted April 9, 2017 (edited) 2017-04-09 02:16, the TV stream restarted again spontaneously and began showing the tv shows from hours ago again: frame=557129 fps= 25 q=25.0 size= 5205525kB time=06:11:34.45 bitrate=1912.7kbits/s speed= 1x frame=557144 fps= 25 q=21.0 size= 5205615kB time=06:11:35.03 bitrate=1912.7kbits/s speed= 1x frame=557159 fps= 25 q=24.0 size= 5205734kB time=06:11:35.61 bitrate=1912.7kbits/s speed= 1x frame=557173 fps= 25 q=21.0 size= 5205803kB time=06:11:36.37 bitrate=1912.7kbits/s speed= 1x frame=557187 fps= 25 q=25.0 size= 5205912kB time=06:11:36.95 bitrate=1912.7kbits/s speed= 1x [http @ 0x67720] Stream ends prematurely at 6522900000, should be 18446744073709551615[mpegts @ 0x67070] PES packet size mismatchframe=557190 fps= 25 q=25.0 size= 5205940kB time=06:11:36.95 bitrate=1912.7kbits/s speed= 1x [mpeg2video @ 0x234730] Invalid mb type in P-frame at 16 28[mpeg2video @ 0x234730] Warning MVs not available[mpeg2video @ 0x234730] concealing 272 DC, 272 AC, 272 MV errors in P framehttp://10.10.10.12:8866/live?channeloid=7168&client=MB3.3: Input/output error Last message repeated 1 timesframe=557193 fps= 25 q=-1.0 Lsize= 5206120kB time=06:11:37.48 bitrate=1912.7kbits/s speed= 1x video:4220722kB audio:522590kB subtitle:0kB other streams:0kB global headers:0kB muxing overhead: 9.757081%[libx264 @ 0x9c3d0] frame I:9659 Avg QP:17.84 size: 35881[libx264 @ 0x9c3d0] frame P:159119 Avg QP:19.38 size: 14353[libx264 @ 0x9c3d0] frame B:388415 Avg QP:21.31 size: 4355[libx264 @ 0x9c3d0] consecutive B-frames: 5.0% 4.7% 4.6% 85.7%[libx264 @ 0x9c3d0] mb I I16..4: 31.6% 0.0% 68.4%[libx264 @ 0x9c3d0] mb P I16..4: 25.0% 0.0% 0.0% P16..4: 58.1% 0.0% 0.0% 0.0% 0.0% skip:16.8%[libx264 @ 0x9c3d0] mb B I16..4: 3.6% 0.0% 0.0% B16..8: 30.6% 0.0% 0.0% direct:14.4% skip:51.4% L0:37.8% L1:48.2% BI:14.0%[libx264 @ 0x9c3d0] coded y,uvDC,uvAC intra: 35.7% 57.5% 25.8% inter: 14.6% 22.2% 0.7%[libx264 @ 0x9c3d0] i16 v,h,dc,p: 43% 33% 13% 11%[libx264 @ 0x9c3d0] i4 v,h,dc,ddl,ddr,vr,hd,vl,hu: 27% 24% 15% 4% 7% 5% 6% 5% 8%[libx264 @ 0x9c3d0] i8c dc,h,v,p: 39% 30% 20% 10%[libx264 @ 0x9c3d0] Weighted P-Frames: Y:4.5% UV:2.0%[libx264 @ 0x9c3d0] kb/s:1550.72 2017-04-09 02:00:19.4845 Error PortMapper: Error creating port map: One or more errors occurred.2017-04-09 02:00:31.3556 Debug PortMapper: Found NAT device: uuid:00000000-0000-0002-0003-5cdc96078d0f::urn:dslforum-org:service:WANPPPConnection:12017-04-09 02:00:31.3556 Debug PortMapper: Calling Nat.Handle on uuid:00000000-0000-0002-0003-5cdc96078d0f::urn:dslforum-org:service:WANPPPConnection:12017-04-09 02:00:31.3556 Debug PortMapper: Found device at: http://10.10.10.254/tr64_igd.xml2017-04-09 02:00:31.3556 Debug PortMapper: Parsed device as: 10.10.10.254:802017-04-09 02:00:31.3556 Debug PortMapper: Fetching service list: 10.10.10.254:802017-04-09 02:00:31.3556 Debug PortMapper: NAT device found: 10.10.10.202017-04-09 02:00:31.3556 Debug PortMapper: NAT device found: 10.10.10.202017-04-09 02:00:31.3556 Debug PortMapper: Found NAT device: uuid:00000000-0000-0002-0003-5cdc96078d0f::urn:dslforum-org:service:WANPPPConnection:12017-04-09 02:00:31.3556 Debug PortMapper: Calling Nat.Handle on uuid:00000000-0000-0002-0003-5cdc96078d0f::urn:dslforum-org:service:WANPPPConnection:12017-04-09 02:00:31.3556 Debug PortMapper: Found device at: http://10.10.10.254/tr64_igd.xml2017-04-09 02:00:31.3556 Debug PortMapper: Parsed device as: 10.10.10.254:802017-04-09 02:00:31.3556 Debug PortMapper: Fetching service list: 10.10.10.254:802017-04-09 02:00:31.3556 Debug PortMapper: NAT device found: 10.10.10.202017-04-09 02:00:31.3556 Debug PortMapper: NAT device found: 10.10.10.202017-04-09 02:00:33.4556 Debug PortMapper: Found NAT device: uuid:00000000-0000-0001-0002-5cdc96078d0f::urn:schemas-upnp-org:service:WANIPConnection:12017-04-09 02:00:33.4556 Debug PortMapper: Calling Nat.Handle on uuid:00000000-0000-0001-0002-5cdc96078d0f::urn:schemas-upnp-org:service:WANIPConnection:12017-04-09 02:00:33.4556 Debug PortMapper: Found device at: http://10.10.10.254/igd.xml2017-04-09 02:00:33.4556 Debug PortMapper: Parsed device as: 10.10.10.254:802017-04-09 02:00:33.4556 Debug PortMapper: Fetching service list: 10.10.10.254:802017-04-09 02:00:33.4556 Debug PortMapper: NAT device found: 10.10.10.202017-04-09 02:00:33.4556 Debug PortMapper: NAT device found: 10.10.10.202017-04-09 02:00:33.4556 Debug PortMapper: Found NAT device: uuid:00000000-0000-0001-0002-5cdc96078d0f::urn:schemas-upnp-org:service:WANIPConnection:12017-04-09 02:00:33.4556 Debug PortMapper: Calling Nat.Handle on uuid:00000000-0000-0001-0002-5cdc96078d0f::urn:schemas-upnp-org:service:WANIPConnection:12017-04-09 02:00:33.4556 Debug PortMapper: Found device at: http://10.10.10.254/igd.xml2017-04-09 02:00:33.4556 Debug PortMapper: Parsed device as: 10.10.10.254:802017-04-09 02:00:33.4556 Debug PortMapper: Fetching service list: 10.10.10.254:802017-04-09 02:00:33.4556 Debug PortMapper: NAT device found: 10.10.10.202017-04-09 02:00:33.4556 Debug PortMapper: NAT device found: 10.10.10.202017-04-09 02:00:33.5064 Debug PortMapper: Found NAT device: uuid:00000000-0000-0001-0002-5cdc96078d0f::urn:schemas-upnp-org:service:WANPPPConnection:12017-04-09 02:00:33.5064 Debug PortMapper: Calling Nat.Handle on uuid:00000000-0000-0001-0002-5cdc96078d0f::urn:schemas-upnp-org:service:WANPPPConnection:12017-04-09 02:00:33.5064 Debug PortMapper: Found device at: http://10.10.10.254/igd.xml2017-04-09 02:00:33.5064 Debug PortMapper: Parsed device as: 10.10.10.254:802017-04-09 02:00:33.5064 Debug PortMapper: Fetching service list: 10.10.10.254:802017-04-09 02:00:33.5064 Debug PortMapper: NAT device found: 10.10.10.202017-04-09 02:00:33.5064 Debug PortMapper: NAT device found: 10.10.10.202017-04-09 02:00:33.5064 Debug PortMapper: Found NAT device: uuid:00000000-0000-0001-0002-5cdc96078d0f::urn:schemas-upnp-org:service:WANPPPConnection:12017-04-09 02:00:33.5064 Debug PortMapper: Calling Nat.Handle on uuid:00000000-0000-0001-0002-5cdc96078d0f::urn:schemas-upnp-org:service:WANPPPConnection:12017-04-09 02:00:33.5064 Debug PortMapper: Found device at: http://10.10.10.254/igd.xml2017-04-09 02:00:33.5064 Debug PortMapper: Parsed device as: 10.10.10.254:802017-04-09 02:00:33.5064 Debug PortMapper: Fetching service list: 10.10.10.254:802017-04-09 02:00:33.5064 Debug PortMapper: NAT device found: 10.10.10.202017-04-09 02:00:33.5064 Debug PortMapper: NAT device found: 10.10.10.202017-04-09 02:07:42.5449 Debug PortMapper: Searching for: PmpSearcher2017-04-09 02:07:43.0650 Debug PortMapper: Searching for: PmpSearcher2017-04-09 02:07:45.0750 Debug PortMapper: Searching for: PmpSearcher2017-04-09 02:07:53.1444 Debug PortMapper: Searching for: PmpSearcher2017-04-09 02:08:25.1965 Debug PortMapper: Searching for: PmpSearcher2017-04-09 02:08:25.5132 Debug PortMapper: Searching for: PmpSearcher2017-04-09 02:08:26.5722 Debug PortMapper: Searching for: PmpSearcher2017-04-09 02:08:30.6766 Debug PortMapper: Searching for: PmpSearcher2017-04-09 02:08:46.6811 Debug PortMapper: Searching for: PmpSearcher2017-04-09 02:10:19.4975 Debug PortMapper: Found NAT device: uuid:33DFDD88-763D-C7A1-3C34-FC7516CACD1B::urn:schemas-upnp-org:service:WANIPConnection:12017-04-09 02:10:19.5002 Debug NetworkManager: Querying interface: lo. Type: Loopback. Status: Unknown2017-04-09 02:10:19.5012 Debug NetworkManager: Querying interface: eth0. Type: Ethernet. Status: Up2017-04-09 02:10:19.5019 Debug PortMapper: Calling Nat.Handle on uuid:33DFDD88-763D-C7A1-3C34-FC7516CACD1B::urn:schemas-upnp-org:service:WANIPConnection:12017-04-09 02:10:19.5019 Debug PortMapper: Found device at: http://10.10.10.100:49152/InternetGatewayDevice.xml2017-04-09 02:10:19.5019 Debug PortMapper: Parsed device as: 10.10.10.100:491522017-04-09 02:10:19.5019 Debug PortMapper: Fetching service list: 10.10.10.100:491522017-04-09 02:10:19.5019 Debug PortMapper: NAT device found: 10.10.10.202017-04-09 02:10:19.5019 Debug PortMapper: Creating port map on port 80962017-04-09 02:10:19.5019 Debug PortMapper: Initiating request to: http://10.10.10.100:491522017-04-09 02:10:19.5031 Debug PortMapper: NAT device found: 10.10.10.202017-04-09 02:10:19.5031 Debug PortMapper: Creating port map on port 80962017-04-09 02:10:19.5031 Debug PortMapper: Initiating request to: http://10.10.10.100:491522017-04-09 02:10:19.5041 Info HttpClient: HttpClientManager POST: http://10.10.10.100:491522017-04-09 02:10:19.5048 Debug PortMapper: Found NAT device: uuid:33DFDD88-763D-C7A1-3C34-FC7516CACD1B::urn:schemas-upnp-org:service:WANIPConnection:12017-04-09 02:10:19.5048 Debug PortMapper: Calling Nat.Handle on uuid:33DFDD88-763D-C7A1-3C34-FC7516CACD1B::urn:schemas-upnp-org:service:WANIPConnection:12017-04-09 02:10:19.5048 Debug PortMapper: Found device at: http://10.10.10.100:49152/InternetGatewayDevice.xml2017-04-09 02:10:19.5048 Debug PortMapper: Parsed device as: 10.10.10.100:491522017-04-09 02:10:19.5048 Debug PortMapper: Fetching service list: 10.10.10.100:491522017-04-09 02:10:19.5048 Debug PortMapper: NAT device found: 10.10.10.202017-04-09 02:10:19.5048 Debug PortMapper: NAT device found: 10.10.10.202017-04-09 02:10:19.5175 Info HttpClient: HttpClientManager POST: http://10.10.10.100:491522017-04-09 02:10:19.5186 Error HttpClient: Error getting response from http://10.10.10.100:49152 *** Error Report *** Version: 3.2.10.0 Command line: /var/packages/EmbyServer/target/server/MediaBrowser.Server.Mono.exe -package synology -programdata /var/packages/EmbyServer/target/var -ffmpeg /var/packages/EmbyServer/target/ffmpeg/bin/ffmpeg -ffprobe /var/packages/EmbyServer/target/ffmpeg/bin/ffprobe -restartpath /var/packages/EmbyServer/scripts/restart Operating system: Unix 3.10.77.0 64-Bit OS: False 64-Bit Process: False Mono: 4.6.2 (Stable 4.6.2.16/ac9e222 Sun Feb 19 10:19:28 CST 2017) Processor count: 4 Program data path: /var/packages/EmbyServer/target/var Application directory: /volume1/@appstore/EmbyServer/releases/v3.2.10 System.AggregateException: One or more errors occurred. ---> System.Net.WebException: The remote server returned an error: (404) Not Found. at System.Net.HttpWebRequest.EndGetResponse (System.IAsyncResult asyncResult) [0x00064] in <5071a6e4a4564e19a2eda0f53e42f9bd>:0 at System.Threading.Tasks.TaskFactory`1[TResult].FromAsyncCoreLogic (System.IAsyncResult iar, System.Func`2[T,TResult] endFunction, System.Action`1[T] endAction, System.Threading.Tasks.Task`1[TResult] promise, System.Boolean requiresSynchronization) [0x00014] in <8f2c484307284b51944a1a13a14c0266>:0 --- End of inner exception stack trace --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <8f2c484307284b51944a1a13a14c0266>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x0004e] in <8f2c484307284b51944a1a13a14c0266>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x0002e] in <8f2c484307284b51944a1a13a14c0266>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x0000b] in <8f2c484307284b51944a1a13a14c0266>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable`1+ConfiguredTaskAwaiter[TResult].GetResult () [0x00000] in <8f2c484307284b51944a1a13a14c0266>:0 at Emby.Common.Implementations.HttpClientManager.HttpClientManager+<SendAsyncInternal>d__22.MoveNext () [0x00405] in <e8f57b20e7ec480ca1d2296615287cdf>:0 ---> (Inner Exception #0) System.Net.WebException: The remote server returned an error: (404) Not Found. at System.Net.HttpWebRequest.EndGetResponse (System.IAsyncResult asyncResult) [0x00064] in <5071a6e4a4564e19a2eda0f53e42f9bd>:0 at System.Threading.Tasks.TaskFactory`1[TResult].FromAsyncCoreLogic (System.IAsyncResult iar, System.Func`2[T,TResult] endFunction, System.Action`1[T] endAction, System.Threading.Tasks.Task`1[TResult] promise, System.Boolean requiresSynchronization) [0x00014] in <8f2c484307284b51944a1a13a14c0266>:0 <--- System.AggregateException at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <8f2c484307284b51944a1a13a14c0266>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x0004e] in <8f2c484307284b51944a1a13a14c0266>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x0002e] in <8f2c484307284b51944a1a13a14c0266>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x0000b] in <8f2c484307284b51944a1a13a14c0266>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable`1+ConfiguredTaskAwaiter[TResult].GetResult () [0x00000] in <8f2c484307284b51944a1a13a14c0266>:0 at Emby.Common.Implementations.HttpClientManager.HttpClientManager+<SendAsyncInternal>d__22.MoveNext () [0x00405] in <e8f57b20e7ec480ca1d2296615287cdf>:0 InnerException: System.Net.WebException System.Net.WebException: The remote server returned an error: (404) Not Found. at System.Net.HttpWebRequest.EndGetResponse (System.IAsyncResult asyncResult) [0x00064] in <5071a6e4a4564e19a2eda0f53e42f9bd>:0 at System.Threading.Tasks.TaskFactory`1[TResult].FromAsyncCoreLogic (System.IAsyncResult iar, System.Func`2[T,TResult] endFunction, System.Action`1[T] endAction, System.Threading.Tasks.Task`1[TResult] promise, System.Boolean requiresSynchronization) [0x00014] in <8f2c484307284b51944a1a13a14c0266>:0 at System.Net.HttpWebRequest.EndGetResponse (System.IAsyncResult asyncResult) [0x00064] in <5071a6e4a4564e19a2eda0f53e42f9bd>:0 at System.Threading.Tasks.TaskFactory`1[TResult].FromAsyncCoreLogic (System.IAsyncResult iar, System.Func`2[T,TResult] endFunction, System.Action`1[T] endAction, System.Threading.Tasks.Task`1[TResult] promise, System.Boolean requiresSynchronization) [0x00014] in <8f2c484307284b51944a1a13a14c0266>:0 2017-04-09 02:10:19.5186 Error PortMapper: Error creating port map: One or more errors occurred.2017-04-09 02:10:19.5243 Error HttpClient: Error getting response from http://10.10.10.100:49152 *** Error Report *** Version: 3.2.10.0 Command line: /var/packages/EmbyServer/target/server/MediaBrowser.Server.Mono.exe -package synology -programdata /var/packages/EmbyServer/target/var -ffmpeg /var/packages/EmbyServer/target/ffmpeg/bin/ffmpeg -ffprobe /var/packages/EmbyServer/target/ffmpeg/bin/ffprobe -restartpath /var/packages/EmbyServer/scripts/restart Operating system: Unix 3.10.77.0 64-Bit OS: False 64-Bit Process: False Mono: 4.6.2 (Stable 4.6.2.16/ac9e222 Sun Feb 19 10:19:28 CST 2017) Processor count: 4 Program data path: /var/packages/EmbyServer/target/var Application directory: /volume1/@appstore/EmbyServer/releases/v3.2.10 System.AggregateException: One or more errors occurred. ---> System.Net.WebException: The remote server returned an error: (404) Not Found. at System.Net.HttpWebRequest.EndGetResponse (System.IAsyncResult asyncResult) [0x00064] in <5071a6e4a4564e19a2eda0f53e42f9bd>:0 at System.Threading.Tasks.TaskFactory`1[TResult].FromAsyncCoreLogic (System.IAsyncResult iar, System.Func`2[T,TResult] endFunction, System.Action`1[T] endAction, System.Threading.Tasks.Task`1[TResult] promise, System.Boolean requiresSynchronization) [0x00014] in <8f2c484307284b51944a1a13a14c0266>:0 --- End of inner exception stack trace --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <8f2c484307284b51944a1a13a14c0266>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x0004e] in <8f2c484307284b51944a1a13a14c0266>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x0002e] in <8f2c484307284b51944a1a13a14c0266>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x0000b] in <8f2c484307284b51944a1a13a14c0266>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable`1+ConfiguredTaskAwaiter[TResult].GetResult () [0x00000] in <8f2c484307284b51944a1a13a14c0266>:0 at Emby.Common.Implementations.HttpClientManager.HttpClientManager+<SendAsyncInternal>d__22.MoveNext () [0x00405] in <e8f57b20e7ec480ca1d2296615287cdf>:0 ---> (Inner Exception #0) System.Net.WebException: The remote server returned an error: (404) Not Found. at System.Net.HttpWebRequest.EndGetResponse (System.IAsyncResult asyncResult) [0x00064] in <5071a6e4a4564e19a2eda0f53e42f9bd>:0 at System.Threading.Tasks.TaskFactory`1[TResult].FromAsyncCoreLogic (System.IAsyncResult iar, System.Func`2[T,TResult] endFunction, System.Action`1[T] endAction, System.Threading.Tasks.Task`1[TResult] promise, System.Boolean requiresSynchronization) [0x00014] in <8f2c484307284b51944a1a13a14c0266>:0 <--- System.AggregateException at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <8f2c484307284b51944a1a13a14c0266>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x0004e] in <8f2c484307284b51944a1a13a14c0266>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x0002e] in <8f2c484307284b51944a1a13a14c0266>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x0000b] in <8f2c484307284b51944a1a13a14c0266>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable`1+ConfiguredTaskAwaiter[TResult].GetResult () [0x00000] in <8f2c484307284b51944a1a13a14c0266>:0 at Emby.Common.Implementations.HttpClientManager.HttpClientManager+<SendAsyncInternal>d__22.MoveNext () [0x00405] in <e8f57b20e7ec480ca1d2296615287cdf>:0 InnerException: System.Net.WebException System.Net.WebException: The remote server returned an error: (404) Not Found. at System.Net.HttpWebRequest.EndGetResponse (System.IAsyncResult asyncResult) [0x00064] in <5071a6e4a4564e19a2eda0f53e42f9bd>:0 at System.Threading.Tasks.TaskFactory`1[TResult].FromAsyncCoreLogic (System.IAsyncResult iar, System.Func`2[T,TResult] endFunction, System.Action`1[T] endAction, System.Threading.Tasks.Task`1[TResult] promise, System.Boolean requiresSynchronization) [0x00014] in <8f2c484307284b51944a1a13a14c0266>:0 at System.Net.HttpWebRequest.EndGetResponse (System.IAsyncResult asyncResult) [0x00064] in <5071a6e4a4564e19a2eda0f53e42f9bd>:0 at System.Threading.Tasks.TaskFactory`1[TResult].FromAsyncCoreLogic (System.IAsyncResult iar, System.Func`2[T,TResult] endFunction, System.Action`1[T] endAction, System.Threading.Tasks.Task`1[TResult] promise, System.Boolean requiresSynchronization) [0x00014] in <8f2c484307284b51944a1a13a14c0266>:0 2017-04-09 02:10:19.5245 Error PortMapper: Error creating port map: One or more errors occurred.2017-04-09 02:15:48.4349 Info TaskManager: IntervalTrigger fired for task: Convert media2017-04-09 02:15:48.4579 Info TaskManager: Queueing task SyncConvertScheduledTask2017-04-09 02:15:48.4579 Info TaskManager: Executing Convert media2017-04-09 02:15:48.4909 Info TaskManager: Convert media Completed after 0 minute(s) and 0 seconds2017-04-09 02:15:48.5599 Info ServerManager: Sending web socket message ScheduledTaskEnded2017-04-09 02:15:48.5599 Info TaskManager: ExecuteQueuedTasks2017-04-09 02:16:47.6612 Debug App: Disposing stream resources2017-04-09 02:16:47.6883 Info MediaSourceManager: Closing live stream 31137e308f44193358c2d4f40ee6b39e_3 with provider LiveTvMediaSourceProvider2017-04-09 02:16:47.6883 Info App: Closing live stream from Next Pvr, stream Id: 32017-04-09 02:16:47.6884 Info App: [NextPvr] Closing 32017-04-09 02:16:47.7326 Info App: FFMpeg exited with code 02017-04-09 02:16:49.2223 Info HttpServer: HTTP Response 200 to 10.10.10.200. Time: 22307140ms. http://10.10.10.20:8096/videos/1d24d7201e823b6327e30a438478df9e/stream.ts?Params=6c1f9fb628213988965aa57595dfa5d5;test;1d24d7201e823b6327e30a438478df9e;false;h264;ac3,aac,mp3;;;23808000;192000;6;30;1920;1080;0;41;;;;;;;;1d24d7201e823b6327e30a438478df9e;false;;;false;;false;;false;false2017-04-09 02:16:56.5356 Info HttpServer: HTTP GET http://10.10.10.20:8096/videos/a77ac4a205bea446e35679d40afec6fc/stream.ts?Params=6c1f9fb628213988965aa57595dfa5d5;test;a77ac4a205bea446e35679d40afec6fc;false;h264;ac3,aac,mp3;;;23808000;192000;6;30;1920;1080;0;41;;;;;;;;a77ac4a205bea446e35679d40afec6fc;false;;;false;;false;;false;false. UserAgent: GStreamer souphttpsrc (compatible; LG NetCast.TV-2013) libsoup/2.34.22017-04-09 02:16:56.5818 Debug NetworkManager: Querying interface: lo. Type: Loopback. Status: Unknown2017-04-09 02:16:56.5828 Debug NetworkManager: Querying interface: eth0. Type: Ethernet. Status: Up2017-04-09 02:16:56.6278 Debug LiveTvMediaSourceProvider: MediaSources: [{"Protocol":"Http","Id":"a77ac4a205bea446e35679d40afec6fc","Path":"http://10.10.10.20:8096","Type":"Default","Name":"TV Drenthe","IsRemote":false,"ReadAtNativeFramerate":false,"SupportsTranscoding":true,"SupportsDirectStream":true,"SupportsDirectPlay":true,"IsInfiniteStream":false,"RequiresOpening":true,"OpenToken":"LiveTvChannel_a77ac4a205bea446e35679d40afec6fc_a77ac4a205bea446e35679d40afec6fc","RequiresClosing":false,"SupportsProbing":true,"BufferMs":1500,"MediaStreams":[],"PlayableStreamFileNames":[],"Formats":[],"RequiredHttpHeaders":{}}]2017-04-09 02:17:23.8529 Info HttpServer: HTTP GET http://10.10.10.20:8096/emby/System/Logs. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:51.0) Gecko/20100101 Firefox/51.0 Cyberfox/51.0.32017-04-09 02:17:23.8565 Info HttpServer: HTTP GET http://10.10.10.20:8096/emby/System/Configuration. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:51.0) Gecko/20100101 Firefox/51.0 Cyberfox/51.0.32017-04-09 02:17:23.8951 Info HttpServer: HTTP Response 200 to 10.10.10.26. Time: 39ms. http://10.10.10.20:8096/emby/System/Configuration2017-04-09 02:17:23.9010 Info HttpServer: HTTP Response 200 to 10.10.10.26. Time: 48ms. http://10.10.10.20:8096/emby/System/Logs2017-04-09 02:17:34.3842 Info HttpServer: HTTP GET http://10.10.10.20:8096/emby/System/Logs/Log?name=server-63627292800.txt. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:51.0) Gecko/20100101 Firefox/51.0 Cyberfox/51.0.3 When I then try to switch to another TV channel at 2017-04-09 02:35:51, it doesn't switch and just restarts and shows the same stream I was watching for the past hours: 2017-04-09 02:32:16.3766 Debug App: Running post-scan task SeriesPostScanTask2017-04-09 02:32:16.3981 Info TaskManager: Scan media library Completed after 0 minute(s) and 2 seconds2017-04-09 02:32:16.4483 Info ServerManager: Sending web socket message ScheduledTaskEnded2017-04-09 02:32:16.4485 Info TaskManager: ExecuteQueuedTasks2017-04-09 02:35:51.9762 Error HttpServer: Error processing request *** Error Report *** Version: 3.2.10.0 Command line: /var/packages/EmbyServer/target/server/MediaBrowser.Server.Mono.exe -package synology -programdata /var/packages/EmbyServer/target/var -ffmpeg /var/packages/EmbyServer/target/ffmpeg/bin/ffmpeg -ffprobe /var/packages/EmbyServer/target/ffmpeg/bin/ffprobe -restartpath /var/packages/EmbyServer/scripts/restart Operating system: Unix 3.10.77.0 64-Bit OS: False 64-Bit Process: False Mono: 4.6.2 (Stable 4.6.2.16/ac9e222 Sun Feb 19 10:19:28 CST 2017) Processor count: 4 Program data path: /var/packages/EmbyServer/target/var Application directory: /volume1/@appstore/EmbyServer/releases/v3.2.10 System.IO.IOException: Unable to write data to the transport connection: Connection reset by peer. ---> System.Net.Sockets.SocketException: Connection reset by peer at System.Net.Sockets.Socket.EndSend (System.IAsyncResult result) [0x00033] in <5071a6e4a4564e19a2eda0f53e42f9bd>:0 at System.Net.Sockets.NetworkStream.EndWrite (System.IAsyncResult asyncResult) [0x0005f] in <5071a6e4a4564e19a2eda0f53e42f9bd>:0 --- End of inner exception stack trace --- at System.Net.Sockets.NetworkStream.EndWrite (System.IAsyncResult asyncResult) [0x000af] in <5071a6e4a4564e19a2eda0f53e42f9bd>:0 at System.IO.Stream.<BeginEndWriteAsync>m__8 (System.IO.Stream stream, System.IAsyncResult asyncResult) [0x00000] in <8f2c484307284b51944a1a13a14c0266>:0 at (wrapper delegate-invoke) System.Func`3[System.IO.Stream,System.IAsyncResult,System.Threading.Tasks.VoidTaskResult]:invoke_TResult_T1_T2 (System.IO.Stream,System.IAsyncResult) at System.Threading.Tasks.TaskFactory`1+FromAsyncTrimPromise`1[TResult,TInstance].Complete (TInstance thisRef, System.Func`3[T1,T2,TResult] endMethod, System.IAsyncResult asyncResult, System.Boolean requiresSynchronization) [0x00002] in <8f2c484307284b51944a1a13a14c0266>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <8f2c484307284b51944a1a13a14c0266>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x0004e] in <8f2c484307284b51944a1a13a14c0266>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x0002e] in <8f2c484307284b51944a1a13a14c0266>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x0000b] in <8f2c484307284b51944a1a13a14c0266>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable+ConfiguredTaskAwaiter.GetResult () [0x00000] in <8f2c484307284b51944a1a13a14c0266>:0 at SocketHttpListener.Net.ResponseStream+<WriteAsync>d__28.MoveNext () [0x001af] in <b1642cda9ed743308421fcb9439b0d2c>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <8f2c484307284b51944a1a13a14c0266>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x0004e] in <8f2c484307284b51944a1a13a14c0266>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x0002e] in <8f2c484307284b51944a1a13a14c0266>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x0000b] in <8f2c484307284b51944a1a13a14c0266>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable+ConfiguredTaskAwaiter.GetResult () [0x00000] in <8f2c484307284b51944a1a13a14c0266>:0 at MediaBrowser.Api.Playback.Progressive.ProgressiveFileCopier+<CopyToAsyncInternal>d__20.MoveNext () [0x000a3] in <ce2593b21c9145aca2477c3f29a99c84>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <8f2c484307284b51944a1a13a14c0266>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x0004e] in <8f2c484307284b51944a1a13a14c0266>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x0002e] in <8f2c484307284b51944a1a13a14c0266>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x0000b] in <8f2c484307284b51944a1a13a14c0266>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable`1+ConfiguredTaskAwaiter[TResult].GetResult () [0x00000] in <8f2c484307284b51944a1a13a14c0266>:0 at MediaBrowser.Api.Playback.Progressive.ProgressiveFileCopier+<WriteToAsync>d__19.MoveNext () [0x0019b] in <ce2593b21c9145aca2477c3f29a99c84>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <8f2c484307284b51944a1a13a14c0266>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x0004e] in <8f2c484307284b51944a1a13a14c0266>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x0002e] in <8f2c484307284b51944a1a13a14c0266>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x0000b] in <8f2c484307284b51944a1a13a14c0266>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable+ConfiguredTaskAwaiter.GetResult () [0x00000] in <8f2c484307284b51944a1a13a14c0266>:0 at Emby.Server.Implementations.Services.ResponseHelper+<WriteToResponseInternal>d__1.MoveNext () [0x00280] in <8aed868ce08848eea7194cd2b0860af9>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <8f2c484307284b51944a1a13a14c0266>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x0004e] in <8f2c484307284b51944a1a13a14c0266>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x0002e] in <8f2c484307284b51944a1a13a14c0266>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x0000b] in <8f2c484307284b51944a1a13a14c0266>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable+ConfiguredTaskAwaiter.GetResult () [0x00000] in <8f2c484307284b51944a1a13a14c0266>:0 at Emby.Server.Implementations.Services.ServiceHandler+<ProcessRequestAsync>d__15.MoveNext () [0x0028f] in <8aed868ce08848eea7194cd2b0860af9>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <8f2c484307284b51944a1a13a14c0266>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x0004e] in <8f2c484307284b51944a1a13a14c0266>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x0002e] in <8f2c484307284b51944a1a13a14c0266>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x0000b] in <8f2c484307284b51944a1a13a14c0266>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable+ConfiguredTaskAwaiter.GetResult () [0x00000] in <8f2c484307284b51944a1a13a14c0266>:0 at Emby.Server.Implementations.HttpServer.HttpListenerHost+<RequestHandler>d__75.MoveNext () [0x005ad] in <8aed868ce08848eea7194cd2b0860af9>:0 System.IO.IOException at System.Net.Sockets.NetworkStream.EndWrite (System.IAsyncResult asyncResult) [0x000af] in <5071a6e4a4564e19a2eda0f53e42f9bd>:0 at System.IO.Stream.<BeginEndWriteAsync>m__8 (System.IO.Stream stream, System.IAsyncResult asyncResult) [0x00000] in <8f2c484307284b51944a1a13a14c0266>:0 at (wrapper delegate-invoke) System.Func`3[System.IO.Stream,System.IAsyncResult,System.Threading.Tasks.VoidTaskResult]:invoke_TResult_T1_T2 (System.IO.Stream,System.IAsyncResult) at System.Threading.Tasks.TaskFactory`1+FromAsyncTrimPromise`1[TResult,TInstance].Complete (TInstance thisRef, System.Func`3[T1,T2,TResult] endMethod, System.IAsyncResult asyncResult, System.Boolean requiresSynchronization) [0x00002] in <8f2c484307284b51944a1a13a14c0266>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <8f2c484307284b51944a1a13a14c0266>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x0004e] in <8f2c484307284b51944a1a13a14c0266>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x0002e] in <8f2c484307284b51944a1a13a14c0266>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x0000b] in <8f2c484307284b51944a1a13a14c0266>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable+ConfiguredTaskAwaiter.GetResult () [0x00000] in <8f2c484307284b51944a1a13a14c0266>:0 at SocketHttpListener.Net.ResponseStream+<WriteAsync>d__28.MoveNext () [0x001af] in <b1642cda9ed743308421fcb9439b0d2c>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <8f2c484307284b51944a1a13a14c0266>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x0004e] in <8f2c484307284b51944a1a13a14c0266>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x0002e] in <8f2c484307284b51944a1a13a14c0266>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x0000b] in <8f2c484307284b51944a1a13a14c0266>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable+ConfiguredTaskAwaiter.GetResult () [0x00000] in <8f2c484307284b51944a1a13a14c0266>:0 at MediaBrowser.Api.Playback.Progressive.ProgressiveFileCopier+<CopyToAsyncInternal>d__20.MoveNext () [0x000a3] in <ce2593b21c9145aca2477c3f29a99c84>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <8f2c484307284b51944a1a13a14c0266>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x0004e] in <8f2c484307284b51944a1a13a14c0266>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x0002e] in <8f2c484307284b51944a1a13a14c0266>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x0000b] in <8f2c484307284b51944a1a13a14c0266>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable`1+ConfiguredTaskAwaiter[TResult].GetResult () [0x00000] in <8f2c484307284b51944a1a13a14c0266>:0 at MediaBrowser.Api.Playback.Progressive.ProgressiveFileCopier+<WriteToAsync>d__19.MoveNext () [0x0019b] in <ce2593b21c9145aca2477c3f29a99c84>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <8f2c484307284b51944a1a13a14c0266>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x0004e] in <8f2c484307284b51944a1a13a14c0266>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x0002e] in <8f2c484307284b51944a1a13a14c0266>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x0000b] in <8f2c484307284b51944a1a13a14c0266>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable+ConfiguredTaskAwaiter.GetResult () [0x00000] in <8f2c484307284b51944a1a13a14c0266>:0 at Emby.Server.Implementations.Services.ResponseHelper+<WriteToResponseInternal>d__1.MoveNext () [0x00280] in <8aed868ce08848eea7194cd2b0860af9>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <8f2c484307284b51944a1a13a14c0266>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x0004e] in <8f2c484307284b51944a1a13a14c0266>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x0002e] in <8f2c484307284b51944a1a13a14c0266>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x0000b] in <8f2c484307284b51944a1a13a14c0266>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable+ConfiguredTaskAwaiter.GetResult () [0x00000] in <8f2c484307284b51944a1a13a14c0266>:0 at Emby.Server.Implementations.Services.ServiceHandler+<ProcessRequestAsync>d__15.MoveNext () [0x0028f] in <8aed868ce08848eea7194cd2b0860af9>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <8f2c484307284b51944a1a13a14c0266>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x0004e] in <8f2c484307284b51944a1a13a14c0266>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x0002e] in <8f2c484307284b51944a1a13a14c0266>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x0000b] in <8f2c484307284b51944a1a13a14c0266>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable+ConfiguredTaskAwaiter.GetResult () [0x00000] in <8f2c484307284b51944a1a13a14c0266>:0 at Emby.Server.Implementations.HttpServer.HttpListenerHost+<RequestHandler>d__75.MoveNext () [0x005ad] in <8aed868ce08848eea7194cd2b0860af9>:0 InnerException: System.Net.Sockets.SocketException System.Net.Sockets.SocketException (0x80004005): Connection reset by peer at System.Net.Sockets.Socket.EndSend (System.IAsyncResult result) [0x00033] in <5071a6e4a4564e19a2eda0f53e42f9bd>:0 at System.Net.Sockets.NetworkStream.EndWrite (System.IAsyncResult asyncResult) [0x0005f] in <5071a6e4a4564e19a2eda0f53e42f9bd>:0 at System.Net.Sockets.Socket.EndSend (System.IAsyncResult result) [0x00033] in <5071a6e4a4564e19a2eda0f53e42f9bd>:0 at System.Net.Sockets.NetworkStream.EndWrite (System.IAsyncResult asyncResult) [0x0005f] in <5071a6e4a4564e19a2eda0f53e42f9bd>:0 2017-04-09 02:35:51.9767 Info HttpServer: HTTP Response 500 to 10.10.10.200. Time: 1135441ms. http://10.10.10.20:8096/videos/a77ac4a205bea446e35679d40afec6fc/stream.ts?Params=6c1f9fb628213988965aa57595dfa5d5;test;a77ac4a205bea446e35679d40afec6fc;false;h264;ac3,aac,mp3;;;23808000;192000;6;30;1920;1080;0;41;;;;;;;;a77ac4a205bea446e35679d40afec6fc;false;;;false;;false;;false;false2017-04-09 02:36:26.8047 Info HttpServer: HTTP GET http://10.10.10.20:8096/videos/c9fa35083bab119bcc37db3d4c6ff8e7/stream.ts?Params=6c1f9fb628213988965aa57595dfa5d5;test;c9fa35083bab119bcc37db3d4c6ff8e7;false;h264;ac3,aac,mp3;;;23808000;192000;6;30;1920;1080;0;41;;;;;;;;c9fa35083bab119bcc37db3d4c6ff8e7;false;;;false;;false;;false;false. UserAgent: GStreamer souphttpsrc (compatible; LG NetCast.TV-2013) libsoup/2.34.22017-04-09 02:36:26.8088 Debug NetworkManager: Querying interface: lo. Type: Loopback. Status: Unknown2017-04-09 02:36:26.8097 Debug NetworkManager: Querying interface: eth0. Type: Ethernet. Status: Up2017-04-09 02:36:26.8133 Debug LiveTvMediaSourceProvider: MediaSources: [{"Protocol":"Http","Id":"c9fa35083bab119bcc37db3d4c6ff8e7","Path":"http://10.10.10.20:8096","Type":"Default","Name":"NPO 1","IsRemote":false,"ReadAtNativeFramerate":false,"SupportsTranscoding":true,"SupportsDirectStream":true,"SupportsDirectPlay":true,"IsInfiniteStream":false,"RequiresOpening":true,"OpenToken":"LiveTvChannel_c9fa35083bab119bcc37db3d4c6ff8e7_c9fa35083bab119bcc37db3d4c6ff8e7","RequiresClosing":false,"SupportsProbing":true,"BufferMs":1500,"MediaStreams":[],"PlayableStreamFileNames":[],"Formats":[],"RequiredHttpHeaders":{}}]2017-04-09 02:36:46.3043 Debug SessionManager: Disposing session controller WebSocketController2017-04-09 02:36:47.8119 Info HttpServer: HTTP GET http://10.10.10.20:8096/web/strings/nl.json?v=1491698207280. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:51.0) Gecko/20100101 Firefox/51.0 Cyberfox/51.0.32017-04-09 02:36:47.8125 Info HttpServer: HTTP GET http://10.10.10.20:8096/web/bower_components/emby-webcomponents/strings/nl.json?v=1491698207280. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:51.0) Gecko/20100101 Firefox/51.0 Cyberfox/51.0.32017-04-09 02:36:47.8216 Info HttpServer: HTTP Response 200 to 10.10.10.26. Time: 9ms. http://10.10.10.20:8096/web/bower_components/emby-webcomponents/strings/nl.json?v=14916982072802017-04-09 02:36:47.8698 Info HttpServer: HTTP Response 200 to 10.10.10.26. Time: 58ms. http://10.10.10.20:8096/web/strings/nl.json?v=14916982072802017-04-09 02:36:48.7197 Info HttpServer: HTTP GET http://10.10.10.20:8096/emby/system/info/public. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:51.0) Gecko/20100101 Firefox/51.0 Cyberfox/51.0.32017-04-09 02:36:48.7249 Info HttpServer: HTTP Response 200 to 10.10.10.26. Time: 5ms. http://10.10.10.20:8096/emby/system/info/public2017-04-09 02:36:48.9344 Info HttpServer: HTTP GET http://10.10.10.20:8096/emby/System/Info. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:51.0) Gecko/20100101 Firefox/51.0 Cyberfox/51.0.32017-04-09 02:36:48.9761 Info HttpServer: HTTP Response 200 to 10.10.10.26. Time: 42ms. http://10.10.10.20:8096/emby/System/Info2017-04-09 02:36:49.0801 Info HttpServer: HTTP GET http://10.10.10.20:8096/emby/users/548a93e5ae994d8884ab5f98eb58bdf6. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:51.0) Gecko/20100101 Firefox/51.0 Cyberfox/51.0.32017-04-09 02:36:49.0847 Info HttpServer: HTTP Response 200 to 10.10.10.26. Time: 5ms. http://10.10.10.20:8096/emby/users/548a93e5ae994d8884ab5f98eb58bdf62017-04-09 02:36:49.1068 Info HttpServer: HTTP POST http://10.10.10.20:8096/emby/Sessions/Capabilities/Full. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:51.0) Gecko/20100101 Firefox/51.0 Cyberfox/51.0.32017-04-09 02:36:49.1149 Info HttpServer: HTTP Response 204 to 10.10.10.26. Time: 8ms. http://10.10.10.20:8096/emby/Sessions/Capabilities/Full2017-04-09 02:36:49.1362 Info HttpServer: HTTP GET http://10.10.10.20:8096/emby/DisplayPreferences/usersettings?userId=548a93e5ae994d8884ab5f98eb58bdf6&client=emby. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:51.0) Gecko/20100101 Firefox/51.0 Cyberfox/51.0.32017-04-09 02:36:49.1432 Info HttpServer: HTTP Response 200 to 10.10.10.26. Time: 7ms. http://10.10.10.20:8096/emby/DisplayPreferences/usersettings?userId=548a93e5ae994d8884ab5f98eb58bdf6&client=emby2017-04-09 02:36:49.1567 Info HttpServer: HTTP GET http://10.10.10.20:8096/emby/Users/548a93e5ae994d8884ab5f98eb58bdf6. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:51.0) Gecko/20100101 Firefox/51.0 Cyberfox/51.0.32017-04-09 02:36:49.1611 Info HttpServer: HTTP Response 200 to 10.10.10.26. Time: 4ms. http://10.10.10.20:8096/emby/Users/548a93e5ae994d8884ab5f98eb58bdf62017-04-09 02:36:49.1741 Info HttpServer: WS ws://10.10.10.20:8096/embywebsocket?api_key=b8f1a208acdb444b9df2d5541ebc0451&deviceId=48f5baaf1753e282b83c555eb838e04308307e9b. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:51.0) Gecko/20100101 Firefox/51.0 Cyberfox/51.0.32017-04-09 02:36:49.1741 Debug HttpServer: Web socket connection allowed2017-04-09 02:36:49.1762 Info HttpServer: HTTP GET http://10.10.10.20:8096/emby/Users/548a93e5ae994d8884ab5f98eb58bdf6. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:51.0) Gecko/20100101 Firefox/51.0 Cyberfox/51.0.32017-04-09 02:36:49.1805 Info HttpServer: HTTP Response 200 to 10.10.10.26. Time: 4ms. http://10.10.10.20:8096/emby/Users/548a93e5ae994d8884ab5f98eb58bdf62017-04-09 02:36:49.2010 Info HttpServer: HTTP GET http://10.10.10.20:8096/emby/Users/548a93e5ae994d8884ab5f98eb58bdf6/Views. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:51.0) Gecko/20100101 Firefox/51.0 Cyberfox/51.0.32017-04-09 02:36:49.2110 Info HttpServer: HTTP Response 200 to 10.10.10.26. Time: 10ms. http://10.10.10.20:8096/emby/Users/548a93e5ae994d8884ab5f98eb58bdf6/Views2017-04-09 02:36:49.7067 Info HttpServer: HTTP GET http://10.10.10.20:8096/emby/System/Logs. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:51.0) Gecko/20100101 Firefox/51.0 Cyberfox/51.0.32017-04-09 02:36:49.7098 Info HttpServer: HTTP GET http://10.10.10.20:8096/emby/System/Configuration. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:51.0) Gecko/20100101 Firefox/51.0 Cyberfox/51.0.32017-04-09 02:36:49.7149 Info HttpServer: HTTP Response 200 to 10.10.10.26. Time: 8ms. http://10.10.10.20:8096/emby/System/Logs2017-04-09 02:36:49.7149 Info HttpServer: HTTP Response 200 to 10.10.10.26. Time: 8ms. http://10.10.10.20:8096/emby/System/Configuration2017-04-09 02:36:49.7511 Info HttpServer: HTTP GET http://10.10.10.20:8096/emby/Notifications/548a93e5ae994d8884ab5f98eb58bdf6/Summary. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:51.0) Gecko/20100101 Firefox/51.0 Cyberfox/51.0.32017-04-09 02:36:49.7565 Info HttpServer: HTTP Response 200 to 10.10.10.26. Time: 5ms. http://10.10.10.20:8096/emby/Notifications/548a93e5ae994d8884ab5f98eb58bdf6/Summary2017-04-09 02:36:49.8050 Info HttpServer: HTTP GET http://10.10.10.20:8096/web/css/images/logoblack.png. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:51.0) Gecko/20100101 Firefox/51.0 Cyberfox/51.0.32017-04-09 02:36:49.8062 Info HttpServer: HTTP Response 304 to 10.10.10.26. Time: 1ms. http://10.10.10.20:8096/web/css/images/logoblack.png2017-04-09 02:36:55.7722 Info HttpServer: HTTP GET http://10.10.10.20:8096/emby/Playback/BitrateTest?Size=500000. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:51.0) Gecko/20100101 Firefox/51.0 Cyberfox/51.0.32017-04-09 02:36:56.0702 Info HttpServer: HTTP Response 200 to 10.10.10.26. Time: 298ms. http://10.10.10.20:8096/emby/Playback/BitrateTest?Size=5000002017-04-09 02:36:56.2853 Info HttpServer: HTTP GET http://10.10.10.20:8096/emby/Playback/BitrateTest?Size=1000000. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:51.0) Gecko/20100101 Firefox/51.0 Cyberfox/51.0.32017-04-09 02:36:56.5276 Info HttpServer: HTTP GET http://10.10.10.20:8096/emby/Playback/BitrateTest?Size=3000000. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:51.0) Gecko/20100101 Firefox/51.0 Cyberfox/51.0.32017-04-09 02:36:57.1968 Info HttpServer: HTTP Response 200 to 10.10.10.26. Time: 912ms. http://10.10.10.20:8096/emby/Playback/BitrateTest?Size=10000002017-04-09 02:36:57.5730 Info HttpServer: HTTP GET http://10.10.10.20:8096/emby/System/Logs/Log?name=server-63627292800.txt. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:51.0) Gecko/20100101 Firefox/51.0 Cyberfox/51.0.3 Edited April 9, 2017 by Rona
Luke 42241 Posted April 9, 2017 Posted April 9, 2017 Hi, we're in process of rolling out 3.2.12. Once that is available for Synology please try that as I think this will be resolved. Thanks !
Rona 0 Posted April 11, 2017 Author Posted April 11, 2017 Ok thanks, that would be great! Looking forward to the update
