asmithau 9 Posted February 10, 2014 Posted February 10, 2014 Hi All, I wanted to update some backdrops for my library menus in the metadata manager and seem to have found an issue. When I upload a new backdrop it will only overwrite the existing image and not add it to the list to allow multiple issues.So basically if I only have one image in the list, it won't allow second. If I already have multiple images available it will overwrite the last image instead, rather than adding an additional image to the list. The server version is 3.0.5135.31685. NB. Its been a while since I changed these images so I'm not sure when this issue may have started. Thanks for your help. Adam
ebr 16354 Posted February 10, 2014 Posted February 10, 2014 I'm not 100% it makes a difference but what do you have set for your maximum backdrops in the server configuration?
asmithau 9 Posted February 11, 2014 Author Posted February 11, 2014 Hi Ebr, Sorry to be a hassle, but I can't seem to find this setting? Adam
Luke 42289 Posted February 11, 2014 Posted February 11, 2014 It won't matter in this case. The setting is in the metadata area and is only used when the server downloads automatically. I'll have to test and see if i can reproduce your issue.
