madvr smooth motion
Go to solution Solved by brad_w,
altramarine
Hi,
Every time i play a video in MBT, i have to uncheck "smooth motion" in madvr settings. If i restart the same video or start another, the smooth motion option is checked back on. It just won't save.
I have Jriver19 installed on the same computer as well and experience no such behavior.
From what i know madvr folder for MBT and Jriver are located in separate folders (not shared), yet settings for one are saved and not for the other.
Any ideas? any registry entry i can force it with?
Thank you,
  • Solution
there's a file in "C:\Users\xxxxxxxxx\AppData\Roaming\MediaBrowser-Theater\config" called "system.xml"; you can disable it from in there by finding "<UseMadVrSmoothMotion>true</UseMadVrSmoothMotion>" and making it "<UseMadVrSmoothMotion>false</UseMadVrSmoothMotion>"
this overwrites the tickbox option in madVR each time you load up a movie from MBT.  looks like it may be a future option in MBT.
once you edit this in the xml file, it will stop forcing it on anymore video/movie files you play
Edited by brad_w
  • Like 1
altramarine
Thank you sir!!!
This did the trick.
I wish Smooth motion coulda worked well for me... but for some reason it doesn't.
Edited by altramarine
