krustyreturns 191 Posted April 30, 2017 Posted April 30, 2017 Yes, I bet that's it. Is using that ignore dts switch you posted an option?
Luke 42237 Posted April 30, 2017 Posted April 30, 2017 Yea I'll add an IgnoreDts property to MediaSourceInfo that you can set to activate this. 1
krustyreturns 191 Posted April 30, 2017 Posted April 30, 2017 That would be great, thank you. Please let me know when it is there.
Luke 42237 Posted April 30, 2017 Posted April 30, 2017 It's in nuget now. If you push an update, use 3.2.14 as the min server version. thanks.
digger11 1 Posted May 28, 2017 Posted May 28, 2017 I came across this thread while looking for a solution to this problem. I was running 3.2.13, so I tried the <GenerateDTS_h264>false</GenerateDTS_h264> workaround, which fixed the problem for me. I then updated the server to 3.2.17 and reverted the serverwmc setting to "true", but the behavior returned. Is there an emby server setting I need to change prior to reverting the serverwmc setting to "true", or should I just leave the serverwmc's GenerateDTS_h264 as "false"?
digger11 1 Posted May 28, 2017 Posted May 28, 2017 (edited) I'm fine with leaving it at false, but based on Krusty's comment in reply 24 of "@Luke, yeah that would probably fix it too (and be better)." I got the impression that maybe I ought to try to revert the setting if possible. Edited May 28, 2017 by digger11
