blastbass 0 Posted April 4, 2017 Posted April 4, 2017 Hello. I have a question about the realtime monitoring process. - When i move a file from a directory already indexed by Emby TO a directory indexed by Emby : the film is not showed by the realtime monitoring. The moving is only see by the planned "Scan Media Library". When the scan is launched, the film appears in the new directory. - What is the delay of the "Realtime monitoring" ? It's probably depending of the number of items indexed by Emby ? Thanks you guys
Luke 42245 Posted April 4, 2017 Posted April 4, 2017 Hi, generally within 2-3 minutes you should see the changes reflected.
blastbass 0 Posted April 5, 2017 Author Posted April 5, 2017 Ok, thanks for the feedback. And concerning the moving ? It's a bug or it's normal ?
Luke 42245 Posted April 5, 2017 Posted April 5, 2017 Same thing. It should generally be reflected within a few minutes. If not then the next library scan will pick it up.
