dredd1963 17 Posted April 4, 2017 Posted April 4, 2017 Morning all Yesterday I noticed a problem while navigating through my libraries ( movies, series & music work ok). For example when i click into my audio books Eveything as expected, but when i click my big finish folder the following happens- All i see is big finish and shuffle, the 3 dot button and favarite button, then i have to click back to see the contents. Then the same happens again when i click on a audiobook and i have to click back again to get to to the tracks i want to play so i can play the track. Also happens on trailers. On the windows stores version and android every thing works ok. Thanks for you time and effort.
Luke 42243 Posted April 4, 2017 Posted April 4, 2017 Can you show a screenshot to demonstrate the issue? thanks !
khodges747 55 Posted April 4, 2017 Posted April 4, 2017 I'm having the same problem (I think) in version 2.5.40 with Folders view. Clicking on any folder brings up a screen like the one attached, which requires me to click "Back" to get to the normal view of my TV shows. The same is true for any folder I try to open. 1
dredd1963 17 Posted April 6, 2017 Author Posted April 6, 2017 Thanks Luke for sorting the problem, it's working nicely now
khodges747 55 Posted April 6, 2017 Posted April 6, 2017 Me too, thanks Luke. This is another case where an update option for Emby Theater might have been useful. If I had opted out of automatic updates I could have waited a few days/weeks for any lingering issues to be cleared up before I installed it. But I also notice that you're now pushing updates without changing the version number, which would make it hard to know what version is "stable".
Luke 42243 Posted February 10, 2018 Posted February 10, 2018 Emby Theater now has sorting, filtering, and view settings on just about every screen. You can now enjoy: Sort order remembered Filters remembered Choose between poster view and list view In poster view you can choose the image you want to use (primary, thumb, etc) You can even hide the title underneath posters if you want Enjoy. 1
