Guest asrequested Posted April 5, 2017 Posted April 5, 2017 Damn! I wish I had a 4K TV. I really want to mess with this. Jeremy was having issues, too. Try changing this to 4, also. That should put it in DXVA native <HwaMode>3</HwaMode>
brad_w 3 Posted April 5, 2017 Posted April 5, 2017 That's not going to cut it. You could try setting HW acceleration to none, but I think you're going to have some problems. Try playing it with kodi, like Jeremy does 4K content rely heavily on the CPU when using hardware acceleration? I was under the impression this was pushing the graphics hardware reason I ask is I've been trying to push the hardware as hard as I can go with chroma scaling algorithms in madVR, but any HEVC content is struggling even on the lowest settings. I figured a GTX1060 would be able to handle it, but never thought of the CPU..
Guest asrequested Posted April 5, 2017 Posted April 5, 2017 does 4K content rely heavily on the CPU when using hardware acceleration? I was under the impression this was pushing the graphics hardware reason I ask is I've been trying to push the hardware as hard as I can go with chroma scaling algorithms in madVR, but any HEVC content is struggling even on the lowest settings. I figured a GTX1060 would be able to handle it, but never thought of the CPU.. HEVC hasn't been added to the HWA codec list, yet. But you can test adding it in the directshowplayer.xml, yourself. <HwaEnabledCodecs> <string>H264</string> <string>VC1</string> <string>MPEG2</string> <string>HEVC</string> </HwaEnabledCodecs>
Luke 42243 Posted April 5, 2017 Posted April 5, 2017 In addition to that, you would need to enable hardware acceleration in the app's video settings.
pir8radio 1313 Posted April 5, 2017 Author Posted April 5, 2017 Damn! I wish I had a 4K TV. I really want to mess with this. Jeremy was having issues, too. Try changing this to 4, also. That should put it in DXVA native <HwaMode>3</HwaMode> During my previous test I tried setting this from the gui by setting hardware acceleration to DXVA, i assume this xml setting does the same as the drop down setting it in the GUI? If not i'll try using the xml.
Guest asrequested Posted April 5, 2017 Posted April 5, 2017 (edited) In the UI there isn't a setting for DXVA2 native, only copyback which requires the GPU to be selected. I'm assuming Babgvant has written that instruction into the XML. DXVA2 native doesn't require that. Setting the number to 4 should use the native setting in LAV. I was just trying to test that option. Can you play 4k 8bit files? Edited April 5, 2017 by Doofus
pir8radio 1313 Posted April 6, 2017 Author Posted April 6, 2017 In the UI there isn't a setting for DXVA2 native, only copyback which requires the GPU to be selected. I'm assuming Babgvant has written that instruction into the XML. DXVA2 native doesn't require that. Setting the number to 4 should use the native setting in LAV. I was just trying to test that option. Can you play 4k 8bit files? no love
Guest asrequested Posted April 6, 2017 Posted April 6, 2017 no love Not 8bit either? And could you play it in Kodi?
pir8radio 1313 Posted April 6, 2017 Author Posted April 6, 2017 Not 8bit either? And could you play it in Kodi? OH... I didn't try an 8 bit movie, ill have to look one up... changing HWA mode to 4 didn't do anything.
Guest asrequested Posted April 6, 2017 Posted April 6, 2017 OH... I didn't try an 8 bit movie, ill have to look one up... changing HWA mode to 4 didn't do anything. Kodi?
Luke 42243 Posted April 6, 2017 Posted April 6, 2017 Here's a version that adds DXVANative to the config screen, and updates the HWCodecs: https://www.dropbox.com/s/a7xerjlofu0r4u7/emby.theater.zip?dl=0 You can just unzip it and run portable. Thanks.
Luke 42243 Posted April 6, 2017 Posted April 6, 2017 In the config file you may also want to set HwaResolution to 7. At the default value, non intel gpu's are excluded from gpu acceleration at 4k resolution. i'll have to ask babgvant about that.
Guest asrequested Posted April 6, 2017 Posted April 6, 2017 (edited) Just testing it. DXVA2 doesn't appear to use the HWA at all, with the resolution set to 1 or 7. I watch my GPU and CPU. GPU frequency barely changes, and CPU assumes all the load. Copyback we know works with HEVC in HWA codec list. UPDATE: Using edge filters, a little more of the GPU is used, but still only half of the bandwidth, around 600MHz of 1150MHz. But I'm only testing with 1080p 10bit Edited April 6, 2017 by Doofus
Luke 42243 Posted April 6, 2017 Posted April 6, 2017 But you're saying it works on the installed version when manually mucking with the config file?
Guest asrequested Posted April 6, 2017 Posted April 6, 2017 But you're saying it works on the installed version when manually mucking with the config file? I'll just retest that. BRB
Guest asrequested Posted April 6, 2017 Posted April 6, 2017 But you're saying it works on the installed version when manually mucking with the config file? Yes.
Luke 42243 Posted April 6, 2017 Posted April 6, 2017 Try setting the config file on the portable install the exact same way.
Guest asrequested Posted April 6, 2017 Posted April 6, 2017 Here are the two configs side by side And here is the result playing with the portable
Guest asrequested Posted April 6, 2017 Posted April 6, 2017 but those are not the same. just overwrite it. That did it. I guess I missed something. This is why I'm not a developer lol
Guest asrequested Posted April 6, 2017 Posted April 6, 2017 Now I see the same system resources being used as I do when using WMP with the installed LAV.
Luke 42243 Posted April 6, 2017 Posted April 6, 2017 Any HwaMode less than 0 = Auto. It looks like it works on Auto, then when you try to force dxvanative it doesn't work. I'll have to ask babgvant about that.
Guest asrequested Posted April 6, 2017 Posted April 6, 2017 Any HwaMode less than 0 = Auto. It looks like it works on Auto, then when you try to force dxvanative it doesn't work. I'll have to ask babgvant about that. But when I set it to 4, it works. You just have to make sure its the last thing you set, and restart the app, or it'll get written over. Here's the other thing that happens with HEVC playback in ET. It doesn't happen in other players.
Guest asrequested Posted April 6, 2017 Posted April 6, 2017 (edited) OK that's weird. When I copy my other config file over, it works. But when I use the UI settings and it rewrites the config, it doesn't work. But the copyback works fine Edited April 6, 2017 by Doofus
Guest asrequested Posted April 6, 2017 Posted April 6, 2017 Any HwaMode less than 0 = Auto. It looks like it works on Auto, then when you try to force dxvanative it doesn't work. I'll have to ask babgvant about that. Oh now I see it! It sets to " -4 "
