Theduke 2 Posted March 31, 2017 Posted March 31, 2017 Hello, I have just upgraded as usually my Emby QNAP server application. I was in version 3.2.8.0 and upgraded to the version 3.2.10.0. The problem is that when now i launch the emby server i got this error : Could not find file "/share/CACHEDEV1_DATA/.qpkg/Emby/Emby/dashboard-ui/index.html". Anyone knows how to solve this problem, i'm stucked. Thanks for you return.
Luke 42239 Posted March 31, 2017 Posted March 31, 2017 Hi @, what if you just open a web browser and visit: {qnap_ip_address}:8096 Does that work?
Theduke 2 Posted March 31, 2017 Author Posted March 31, 2017 (edited) I did this : 1/ Downgrade to version 3.2.9.0 and everything worked fine 2/ Upgrade to version 3.2.10.0 but links are not working and all entries are in english (not french) like if some templates or translation were missing. Strange behavior. Configuration details : QTS 4.2.4 QMono 4.6.2.7 FFmpeg 3.2.3 Edited April 1, 2017 by peyrusse
Guest Posted March 31, 2017 Posted March 31, 2017 Hi, I have the same problem, when I was upgrading from 3.2.9.0 to 3.2.10.0 I first saw the strange WebUI like in the image from peyrusse. Translations for the single buttons, labesl, tabs, etc. seems to be missing. When I refreshed the site, I got the error message: Could not find file "/share/CACHEDEV1_DATA/.qpkg/Emby/Emby/dashboard-ui/index.html". Restarting the emby server has no effect, the WebUI may not be loaded anymore, always the same error message. I had installed the emby server via the Qnapclub App Center. I have already removed the version and installed V3.2.9.0 via QPKG package, and this is working fine (unfortunatly my library is now gone, and I have to rebuild it). When installing V3.2.10.0 via QPKG the same problem occured. I then tried to locate the file which seems to be missing using SSH. Maybe there is a problem with path substitution, or something like this. I could not locate /share/CACHEDEV1_DATA/.qpkg/Emby/Emby/dashboard-ui/index.html but /share/CACHEDEV1_DATA/.qpkg/Emby/Emby/dashboard-ui/dashboard-ui/index.html Can you please check, and see if there is a mixup in the last release with building the URLs for the WebUI. Is there any other possibility to configure the server? Thank you very much in advance. Reguards Bubblegumtrash
HTPCS 1 Posted March 31, 2017 Posted March 31, 2017 Same issue, but since there is no major upgrades i need 3.2.9 is sufficient for me
Luke 42239 Posted March 31, 2017 Posted March 31, 2017 It's being looked into thanks for the report guys.
rocam1981 0 Posted April 1, 2017 Posted April 1, 2017 (edited) Same here rolling back - Luke I will update my other posts after confirming 3.2.9 works on my 251A Tested GOOD> Go to latest qmono and 3.2.9 QNAP must be on 4.3 beta Edited April 1, 2017 by rocam1981
rocam1981 0 Posted April 1, 2017 Posted April 1, 2017 Tested GOOD> Go to latest qmono and 3.2.9 QNAP must be on 4.3 beta
One2Go 121 Posted April 1, 2017 Posted April 1, 2017 Version 3.2.10 introduced an additional dashboard-ui part in the links, all the HTML files are located in "/share/CACHEDEV1_DATA/.qpkg/Emby/Emby/dashboard-ui/dashboard-ui/ but are not accessible from the dashboard.
Luke 42239 Posted April 1, 2017 Posted April 1, 2017 I've been notified by QNAP that they released a new update that resolves this. Thanks !
Theduke 2 Posted April 2, 2017 Author Posted April 2, 2017 (edited) Great thanks Luke for your help. I confirm the problem is solved. Edited April 2, 2017 by peyrusse
Guest Posted April 2, 2017 Posted April 2, 2017 Hi, The new Version 3.2.10.1 is working now. Thanks for the quick response.
